Thread: Brake fluid color
Results 1 to 8 of 8
  1. #1 Brake fluid color
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    So on my gtp with 264,xxx miles, the brake fluid is starting to look like a dark color which puts up a red flag in my head.
    What does dark fluid mean though? is something getting into the system??
  2. #2 Re: Brake fluid color
    your fluid is just old. you can flush it.
  3. #3 Re: Brake fluid color
    It's dirty.. old and not working it's best
    Flush it til it's clear. You'll likely feel a difference
  4. #4 Re: Brake fluid color
    Feb 2013
    37.295091, -121.930053
    good clean fluid is the only way.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Brake fluid color
    I've done it the red neck way too, suck the fluid out of the res or soak it up with a rag, then fill with new and do that again a few days later. Hitting a dirt parking lot of dirt road to pulse the ABS system helps too.
  6. #6 Re: Brake fluid color
    that will never clear out the old fluid in the calipers tho.
    i turkey baster out the master res dry, fill with new fluid, then start rr to lr then rf then lf. bleed each wheel caliper till clear new brake fluid comes out the bleeder of each caliper.
    dont let the master run dry, keep it topped off.
  7. #7 Re: Brake fluid color
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ScottyDoggs View Post
    That will never clear out all the old fluid in the calipers though.
    I use a turkey baster to remove all the old fluid from the reservoir, then I fill with it with new brake fluid, then start rr to lr then rf then lf. Bleed each wheel caliper until clear brake fluid comes out.
    do not let the master cylinder reservoir run dry, keep it topped off.
    Fixed that for you... again
  8. #8 Re: Brake fluid color
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
  1. Low brake fluid
    By brenglen in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2013, 11:04 PM
  2. Fluid Color after Lucas added
    By Burbman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2012, 09:40 AM
  3. Low Brake Fluid??
    By jezzer in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 10:12 AM
  4. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  5. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
