Thread: SD Headers C5 shorter o2 sensor.
Results 1 to 14 of 14
  1. #1 SD Headers C5 shorter o2 sensor.
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Does anyone have the part number for the rear C5 o2 sensor that works with our upstream sensor?
    Ive been doing a little research and ive found that the 13111 is compatible but is still too big.
    I also found this link on here:
    http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
    I wanted to confirm that it would work before i bought it. I know that it will require splicing.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: SD Headers C5 shorter o2 sensor.
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    It's the denso o2...not sure on part number,maybe pm blueguy...he would have more info for sure!
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  3. #3 Re: SD Headers C5 shorter o2 sensor.
    iirc you have to un pin the wires in the plug of the vette o2 and move them so they work.
  4. #4 Re: SD Headers C5 shorter o2 sensor.
    Apr 2014
    South Haven, MI
    Does anyone have a diagram for that?
  5. #5 Re: SD Headers C5 shorter o2 sensor.
    iirc it was blue guy who said it, iirc he said you can hold the two side by side, then move the colored wires so they are in the stock plugs location.
  6. #6 Re: SD Headers C5 shorter o2 sensor.
    Apr 2014
    South Haven, MI
    That sounds simple enough.
  7. #7 Re: SD Headers C5 shorter o2 sensor.
    Apr 2014
    South Haven, MI
    A=low signal
    B=high signal
    C=ground
    D=PCM
    ours: A=TAN B=PPL C=BLK D=PNK
    C5: A=TAN B=PPL C=BLK D=BRN
  8. #8 Re: SD Headers C5 shorter o2 sensor.
    Apr 2014
    South Haven, MI
    ^^^That may have solved my problem.
  9. #9 Re: SD Headers C5 shorter o2 sensor.
    I'd rather just weld a bung in the crossover.
  10. #10 Re: SD Headers C5 shorter o2 sensor.
    thats what i did.
  11. #11 Re: SD Headers C5 shorter o2 sensor.
    Mar 2014
    Tucson
    This cost $0.
  12. #12 Re: SD Headers C5 shorter o2 sensor.
    Topeka, KS
    Which Denso is it?
    Part # 234-4212
    Part # 234-4668
    Thanks
    Ryno
  13. #13 Re: SD Headers C5 shorter o2 sensor.
    Topeka, KS
    For the record, I used a Bosch 13444
    I beat the piss out of my firewall until I was tired of it. Then I got smart and took off the dog bones giving me more room to put the o2 sensor in.
  14. #14 Re: SD Headers C5 shorter o2 sensor.
    Donating Users
    Kansas City
    Quote Originally Posted by rynoman03 View Post
    U so smurt, Rian
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  1. Making O2 sensor extension for headers - which wire goes where?
    By Elite6 in forum General Tech Discussion
    Last Post: 09-07-2012, 11:17 AM
  2. SSAC Headers and Shorter Dog Bones Question
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2012, 03:05 PM
  3. o2 sensor with new headers question
    By gtpdriver in forum General Tech Discussion
    Last Post: 02-14-2011, 12:11 AM
  4. o2 sensor extention for headers
    By Or GTP in forum General Tech Discussion
    Last Post: 08-23-2010, 05:26 PM
  5. O2 Sensor with headers
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2009, 04:55 PM
