Thread: springs recommended for yella terra 1.95 rockers
Results 1 to 15 of 15
  1. #1 springs recommended for yella terra 1.95 rockers
    SE Level Member 40thAnnGTP2002's Avatar
    May 2015
    high point nc
    i have a set of yella terra 1.95 rockers coming to me and i have a gen v swap with 3.5 pulley to put on this weekend, sd headers, lucas 42.5lb injectors, 3" maganflow converter, drilled 180* tstat, autolite 104s, ac delco factory wires, zzp pcm tune for the setup.
    i have 2 sets of springs i got form a junkyard looking to get some info on them. one is from a corvette and they have a purple stripe and the other is from a 05 gto and they have an orange stripe. would one of them be beneficial to my setup or should i just buy the blue ls6 springs? any info would b greatly appreciated.
    The joy of getting pulled on an interstate...
    Cop: "License & Registration, Do you know how fast you were going?" Me:"I was just trying to keep up with the traffic." Cop Looks Around:"There is no traffic." Me: "I know, that's how far behind I am!!!"
  2. #2 Re: springs recommended for yella terra 1.95 rockers
    Kemmerer, Wyoming
    What color are the springs? Both sets that you already have should be the 90lb ls style valve spring
  3. #3 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    one set is gray with purple stripe(from the corvette) and the other gray with orange stripe(from the 05 gto)
  4. #4 Re: springs recommended for yella terra 1.95 rockers
    my 1.95 rockers came with 90 lb LS springs. they came with new retainers too. i never did a side by side, so i dont know if they are any different then stock.
  5. #5 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    i bought just the rockers from gambler67 on here so thats why im looking for springs bc i want to do it all while im in and plus those rockers wont work with stock springs lol
  6. #6 Re: springs recommended for yella terra 1.95 rockers
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    From google, the orange and purple stripped springs are LS1 springs are rated at 70# seat pressure at a install height of 1.8
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  7. #7 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    Thank you for that info. That was very helpful.
  8. #8 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    hello again guys i just had a question... a guy has a set of pbm 110# valve springs for sale and i was owndering if that would be great for my setup or stick to the 105# crows?
  9. #9 Re: springs recommended for yella terra 1.95 rockers
    It doesn't really matter, both are more than enough.
    You could honestly run L76 springs and be totally fine.
  10. #10 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    ok im sorry if im showing im a newbie but what are silver iirc ls6 springs?
  11. #11 Re: springs recommended for yella terra 1.95 rockers
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Cheapest and easiest route are going to be L76 springs. Do a google search and you'll come up with the part number. I tend to stay away from LS6 springs. L76 are easiest to get and cheap, Crow 105's are what I'd be running because I prefer to have more spring pressure than not enough.......also the Crow 105's were nice on my timing chain dampner.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  12. #12 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    thank you or the info im sold on the crow 105s, going to order them tomo from intense. im just studying about the different springs to learn about them and the diff combos with rockers and such.
  13. #13 Re: springs recommended for yella terra 1.95 rockers
    May 2015
    high point nc
    so i was about to order the crow 105# springs when i came across a set of comp 105# springs brand new in the box sealed for $75... which way should i go?
  14. #14 Re: springs recommended for yella terra 1.95 rockers
    Apr 2014
    South Haven, MI
    The crow springs are better. Ive talked to a few people who have had first hand experience with the comp 105s breaking.
  15. #15 Re: springs recommended for yella terra 1.95 rockers
    Dec 2013
    laporte mn
    I used 90# springs with those exact rockers. Never had an issue. I know I'm late to the game but just putting this in here for future input for people
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  1. SALE Yella Terra 1.8 Roller Rockers
    By 05grndprix in forum For Sale - Parts
    Last Post: 10-21-2013, 09:38 PM
  2. 1.9 terra yella roller rockers
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 11:17 AM
  3. Yella terra's vs. zzp's modded rockers
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2009, 08:41 AM
