Thread: Plog install help.
Results 1 to 13 of 13
  1. #1 Plog install help.
    Jul 2014
    Belfast, me
    Do they make a plog install kit or does anyone have the thread specs on the manifold bolts so I can buy some. I'd get them on zzp I just am an impatient person and want to get my plog on.
  2. #2 Re: Plog install help.
    Kemmerer, Wyoming
    doesn't your exhaust manifold already have studs? just reuse the old ones
  3. #3 Re: Plog install help.
    Jul 2014
    Belfast, me
    If they nuts don't come out. I want to have everything so the car isn't down. I have to drive to use it as a dd.
  4. #4 Re: Plog install help.
    Kemmerer, Wyoming
    The nuts don't come off the studs
  5. #5 Re: Plog install help.
    Jul 2014
    Belfast, me
    I've been soaking them down with pb blast on and off for about 2 weeks now so I'm hoping they should all come out easily. Any tips on taking them out??
  6. #6 Re: Plog install help.
    May 2008
    Winnipeg, MB
    two weeks and things aren't coming apart yet? poor engine
    I have two that are snapped and the PLOG seals just fine on the remaining four studs so don't have a heart attack if something breaks.
    2007 Pontiac Grand Prix
  7. #7 Re: Plog install help.
    my manifold bolts came right out, reused them twice now. one stud/nut combo dont come apart, its got two nuts but one dont move. its the one holding the dip stick tube in place. make sure that one goes back in where it came out.
    the two ends are nuts on a stud, just take the nuts off leave the studs in place, they hold the gasket in place for you. re use the stock gasket.
  8. #8 Re: Plog install help.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    run the engine for 30 seconds to get them warm. then try loosening.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Plog install help.
    Jul 2014
    Belfast, me
    I haven't tried getting then out yet. I wanted to soak them for a little while longer
  10. #10 Re: Plog install help.
    I took mine off of a 240~k mile pile of sh1t in about 30~ minutes.
    Exhaust stuff, minus the catback and downpipe bolts...should be the last thing that snaps.
  11. #11 Re: Plog install help.
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    They came out no problem when installing on my 168k mile regal. Used a 3/8" breaker bar and 6 pt deep socket to break them loose, even the xover bolts came out just fine after soaking with PB ~30 minutes before removal. Just worked them back and forth until they turned nice and smooth. If you break one of those, I believe it's rocker bolts that will work in their place.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: Plog install help.
    Jul 2014
    Belfast, me
    Awesome guys! I'm going to try it out today
  13. #13 Re: Plog install help.
    Jul 2014
    Belfast, me
    Installed the manifold. So easy!! I struggled with the dipstick tube then consulted with Google and pulled up a how to and wham bam done!! What a difference it made.
  1. Wtb- mps plog 3.6
    By wa04compg in forum Wanted To Buy - Parts
    Last Post: 06-18-2012, 08:22 PM
  2. PLOG install not going well
    By tod1d in forum General Tech Discussion
    Last Post: 05-15-2012, 02:37 PM
  3. WTB rear turbo plog, front plog and Z7 Crossover
    By Wotgtp in forum Wanted To Buy - Parts
    Last Post: 02-20-2012, 07:39 AM
  4. How hard is it to install a plog and 3.4 pulley
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 02-07-2011, 06:40 AM
  5. Do I need a gasket for a PLOG install?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 01:11 AM
