Thread: Top Swapped Pulley drop VS L67 Pulley Drop
Results 1 to 9 of 9
  1. #1 Top Swapped Pulley drop VS L67 Pulley Drop
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    All i really want to know is how much of a difference a 3.4 is on a 8.5 (L67) compression block vs a 9.4 compression block (L36).
    Would running a 3.4 on the top swap be similar to running a 3.3-3.2 on a GTP engine as far as supporting mods go?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    Kemmerer, Wyoming
    a top swapped car makes about 20 more horsepower than an L67 on the same pulley, that is if there are enough flow mods. what goes in must come out.
  3. #3 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    GTP Level Member
    Jan 2015
    Lincoln, NE
    you're correct. 3.4=3.2 on a top swap car.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  4. #4 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    a 3.4 pulley is really pushing it. a ic would be best.
    i had a rocker, 3.4 l67. the l36 top swap with rockers and the stock pulley would have blown the l67's doors off.
    i tried the 3.4 on the top swap, i was getting tons of KR at part throttle. and im talking 1/4 throttle. 6ยบ kr
  5. #5 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    Apr 2014
    South Haven, MI
    6* at 25%? Holy crap. Im on a 3.3 and see no knock.
  6. #6 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    you have a cam.
    i got no real mods other then the headers and the rockers. heads are lightly ported but clearly that didnt help.
    ic will be paid for on friday night let the pulley dropping commence.........
  7. #7 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    Just because you saw knock, doesnt mean everyone will.
    Lots of people might be able to get away without a intercooler.
  8. #8 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    Banned
    Jan 2013
    maryland
    This.
    Im on a 2.8 with no knock on a e85 cam and genv with no intercooler i will get one before the year is over to dyno and drop to a 2.6
    Sent from my LG-D851 using Tapatalk
  9. #9 Re: Top Swapped Pulley drop VS L67 Pulley Drop
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    The blue POS is on a 3.2 with roughly 9.5-10 lbs of boost with headers, and slightly ported heads and an XP. Once I figure out my fueling I'll try my 3.0 but I'd rather play it safe for now.
    Now the 03 has an IC and I see blips of KR with rockers and a full size intercooler/headers, etc. about 10-12 lbs of boost.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  1. pulley drop
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 11:41 PM
  2. 3.4 pulley drop
    By hollas13 in forum General Tech Discussion
    Last Post: 07-18-2013, 08:36 AM
  3. Should i drop to a 2.8 pulley?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2013, 12:43 PM
  4. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  5. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
