Just looking for other possibilities and tips.
I am going to go rent a fuel pressure gauge to test the pump tonight.
Here is what is happening. The car starts up fine, idles fine and under a light load accelerates fine. No check engine light. When I put the pedal down and it hits 3000 rpm it starts to hesitate. It actually feels like the injectors are being shut down or the spark plugs are being shut down. As long as I go easy on it, it does fine. I also replaced the fuel filter first thing.
At this point, only thing I can think of that could be the problem is the fuel pump, because as far as I understand just about anything else would throw a engine code, which right now there are none. Any further suggestions or tips? TIA
