Thread: Speed Daddy install issue
Results 1 to 20 of 22
  1. #1 Speed Daddy install issue
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Well, my headers are 99% put on. The only issue im having is the location of the o2 sensor bung. I tried using an air hammer to dent the firewall in but for some reason it didn't work. I know it wouldn't be very advisable to do this, but could i grab an o2 extension and relocate the upstream to the downstream area temporarily until i can throw my car on a lift and use a small sledge hammer to dent the firewall. My other option is to buy one of the o2 elbows from ZZP.
    http://zzperformance.com/3800/exhaus...-extender.html
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Speed Daddy install issue
    you can move the bung. mines in the cross over pipe, im sure down in the goose neck area would be fine too.
    you can cut the o2 plug off the cars harness and add wire to it to make your own extension.
  3. #3 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    My parts car has an extension harness already on it along with a different trans dipstick that doesn't get in the way of the headers. And on a side note, you always seem to be the first post on anything i post lol.
  4. #4 Re: Speed Daddy install issue
    He lives on the internet.
  5. #5 Re: Speed Daddy install issue
    Mar 2014
    Tucson
    He lives in the Matrix.
    Fixed. Ha
  6. #6 Re: Speed Daddy install issue
    i am the matrix lol
  7. #7 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    Well, i need the car tomorrow so ill just buy the elbow and see if that works for a temp fix.
  8. #8 Re: Speed Daddy install issue
    the o2 will still fit in the bung, its just gonna hit the fire wall some.
  9. #9 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    I tried that. Ill need to get it on the lift though to get some power at it. The air hammer didn't work, but i might not have been using it right.
  10. #10 Re: Speed Daddy install issue
    what im saying is you can install the o2 in that bung for now. with out beating the firewall. if you need to get around, then you also know exactly where you need to beat the wall in.
  11. #11 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    Its too tight of a fit though to just screw it into the motor. I can get a picture tomorrow of what i have to work with.
  12. #12 Re: Speed Daddy install issue
    i had to go at it on a angle, it just clears the fire wall. it hits when the engine moves.
    if you have the engine pulled forward let it go back you'll have more room.
  13. #13 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    The engine is currently in its original spot. I may just have an odd car.
  14. #14 Speed Daddy install issue
    Trying pulling the motor forward, then installing the o2 then putting it back into Its original position.. Or just letting it go back (unhooking both dogbones) maybe you'll be able to get it in then.
    04 Comp G.
  15. #15 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    Ill try that before i buy anything. Thanks scotty and redcompg
  16. #16 Re: Speed Daddy install issue
    air hammer didn't work for you? I was able to massage the firewall with one.. quite a few times.. You need to mark where the sensor goes and remove the rear header again.. it's not bad if you keep the jack under it.
  17. #17 Re: Speed Daddy install issue
    Buffalo
    How do these companies mock-up their product ? How did it fit for them?
    same issue across various platforms
    they make a cold air intake for a mustang. The MAF is too big and does not fit in the CAI at all. Can't even modify it as the MAF would still be exposed
    the v6 headers they make for the eclipse , the front and rear cross over pipes don't align or meet up at all. It's shifted 3" to the right and there is a. 4" gap between the two. You have to cut the flanges and have a shop weld them together AFTER heating and moving them in alignment. This also stressed the flex section.
    So the option is $1,100 set of pipes from 1 company. No way am I going to buy that until I get my SDS super charger installed
  18. #18 Re: Speed Daddy install issue
    Enfield, CT
    I'm just surprised that SD hasn't moved the bung location after all this time. I used a ball peen hammer on the firewall about 4-5 times and it worked out perfectly.
    Sent from my LG G3
  19. #19 Re: Speed Daddy install issue
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    They already did one revision, my psych teacher had an older style set and the crossover didn't come close to fitting and needed to be cut/welded
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  20. #20 Re: Speed Daddy install issue
    Apr 2014
    South Haven, MI
    I got the o2 on by removing the rear header and beating the **** out of the fire wall with a ball peen hammer. It worked like a charm. I just got done taking the car around the block while scanning for KR. I am now KR free...
  1. Rear speed daddy headers figment issue
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 08-21-2015, 10:47 AM
  2. OBX vs Speed Daddy
    By JB122894 in forum General Grand Prix Discussion
    Last Post: 03-13-2013, 06:25 PM
  3. Speed daddy header egr issue
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2011, 05:47 PM
  4. Speed Daddy Header install writeup
    By vailskier3 in forum General Tech Discussion
    Last Post: 10-26-2011, 09:28 AM
  5. speed daddy's
    By Feminist turnip in forum 04+ Specifics
    Last Post: 02-02-2011, 08:53 AM
