Thread: Crappy day.... how to break the seal on LIM gasket?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 105
  1. #41 Re: Crappy day.... how to break the seal on LIM gasket?
    i think your rad cap maybe bad, or not on right, aka hooked on both sides. the tank will rise and drop, but if you squeeze the upper hose and coolant blows into the res tank, the caps not tight or shot for sure.
    the side rubber side gasket has nothing to do with coolant, its just sealing air from getting inside to outside.
    check your oil. if the dip stick has any milky looking crap on it, change it asap.
    if you just see clean new oil on the stick the oil is fine.
  2. #42 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Yeah the oil is clean. No bubbles or milky residue. I even did the blot test on a business card and it absorbed into the card without leaving any sticky residue behind. I'm changing the oil one more time to set my mind at ease.
    I hate doing big jobs like this, I find myself continually analyzing every bit of info possible afterwards thinking something went wrong.
    I've done of few of those jobs where everything is hooked back up and you find an extra nut or two. Not a good feeling.
  3. #43 Re: Crappy day.... how to break the seal on LIM gasket?
    Feb 2013
    37.295091, -121.930053
    finding extra nuts and bolts are not a big deal finding extra parts thats when you should worry
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #44 Re: Crappy day.... how to break the seal on LIM gasket?
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    If you put it back together and you have a couple extra nuts and bolts that means you are legit, you found a way to put it back together with less than what came from the factory, efficiency! haha.
  5. #45 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Apparently those rail seals also keep oil from leaking out of the lifter valley. ill have to keep an eye out and make sure they don't leak.
  6. #46 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    I'm going to have to get some degreaser and spray the accessories down along with the belt. Squealing all the time now. Coolant got every damn where.
  7. #47 Re: Crappy day.... how to break the seal on LIM gasket?
    you can just hose the engine down. take the belts off and make sure they are clean. check the pulleys all spin nice too.
  8. #48 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    The wear pattern on my tensioner pulley seems uneven. Instead of the wear being the width of the belt I've got racing stripes along the circumference of the pulley.... If cleaning doesn't fix it there's a good chance the duralast tensioner I put on years back isn't worth a crap....
    It spins freely however I'll have to check alignment.
  9. #49 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Wonderful. Sounds like the squeal is coming from the water pump underneath and to the front of the idler. That would explain the noise and loss of coolant
  10. #50 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Oil looks good. Had air bubbles in it but no coolant smell or discoloration
  11. #51 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Looks I'll be replacing the front cover on the water pump. I checked the belt system out and I had a few small drops of some kind of fluid on the harmonic balancer. It sits directly under the water pump pulley.
  12. #52 Re: Crappy day.... how to break the seal on LIM gasket?
    that sounds like a water pump leak. it leaks out the weep hole under the pulley in its snout.
    car off, grab the w/p pulley with both hands, push one, pull the other, then back and fourth, if you feel play the w/p is shot.
  13. #53 Re: Crappy day.... how to break the seal on LIM gasket?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    They suck replacing btw I hated doing mine
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  14. #54 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    This car is going to keep me busy for a while. Then again I've put 65k on it in 3.5 years
  15. #55 Re: Crappy day.... how to break the seal on LIM gasket?
    water pump aint all that bad. sucky part is you need to take the power steering pump off and the lower idler for the sc belt, t55 torx or a 15 mm on some. its got normal threads, just take the pulley off and the long w/p bolt comes out.
    same deal with the p/s pump, its blocking a long bolt to the pump.
  16. #56 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Quote Originally Posted by ScottyDoggs View Post
    Looking at this one all I gotta do is remove the pulley and the small bolts holding the front cover on.
  17. #57 Re: Crappy day.... how to break the seal on LIM gasket?
    and the p/s pump will have to come off. i keep forgetting your n/a no lower idler.
    no way around the p/s pump tho. its coming off.
    loosen up the 4 w/p pulley bolts, then take the belt off. makes life easy for them
  18. #58 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    I may just hold off the job until I get my steering rack replaced in that case. Its leaking internally and the unequal pressure is making the steering when pull slightly left. If I have to unhook the PS pump from the hoses ill need to bleed it anyways.
  19. #59 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Good news is the overflow tank has returned to the full line and the coolant level hasn't changed since the last top off yesterday, so the accident involving the elbow and gasket replacement wasn't in vain.
  20. #60 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Waterpump is bad I botched the job. Just started the the car via remote start and as I was approaching it I got a whiff of an overwhelmingly sweet odor. Seemed to be coming from the passenger side but the rear of the engine is also possible. Ill place cardboard under both areas tonight and find out which it is. The smell isn't present while driving so I'm hoping its the water pump. Crossing my fingers.
  1. 3800 rear main seal cover plate gasket orientation
    By Lou and Blue in forum General Tech Discussion
    Last Post: 10-13-2015, 04:28 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
  4. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  5. Diff Housing seal or gasket
    By MnRedGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:18 PM
