Thread: Crappy day.... how to break the seal on LIM gasket?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 105
  1. #21 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    The good news is it wasn't anything near as hard as the lim I did on my old 3100
  2. #22 Re: Crappy day.... how to break the seal on LIM gasket?
    ive seen those jobs, looks like a real b1tch. at least the rockers can stay on this time lol
  3. #23 Re: Crappy day.... how to break the seal on LIM gasket?
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Sorry, I wasn't saying you would have to do the head gaskets, I was stating that I personally have done something similar and in my case I was scoping out a cylinder with a video scope and lost the attachment.
  4. #24 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Oh ok. My fault. I thought you were using the attachment to find the piece of elbow lol.
  5. #25 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Almost done. just gotta get the uim and alternator/tensioner back on. How long should I allow for the rtv to dry before firing it up? Don't have to be to work for another 11 hours. RTVs been sealed up for 2 hours
  6. #26 Re: Crappy day.... how to break the seal on LIM gasket?
    Fire it at will. No need to wait.
  7. #27 Re: Crappy day.... how to break the seal on LIM gasket?
    also do a oil and filter change before you start it up. then if you see any thing but new clean oil on the dip stick after it runs for a few minutes, change the oil and filter one more time.
  8. #28 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Meh. I run synthetic. Ill get el cheapo walmart oil.
  9. #29 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Ok everthing is back together and checks out. No leaks. However since I was in a rush to get it all back together and catch a nap, I managed to break the 7mm head of the coolant bleeder screw. I grabbed a 10mm for the larger head underneath and finished bleeding it. Do I need to replace thr screw or am I good? Doesn't appear to be leaking.
  10. #30 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    All that trouble just for this...
    how to screenshot on windows
  11. #31 Re: Crappy day.... how to break the seal on LIM gasket?
    May I compliment you on your choice of footwear, it was my choice most of the time as well.
    If it's not leaking.. leave it be. Burp through the rad cap opening instead. You'll be fine.
  12. #32 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    I grabbed another one anyways. 8 bucks on rock auto and instead of the 7mm bleeder valve it has a small screw in it that can be loosened and tightened with a flat head. If I break the head off this one I've got issues.
  13. #33 Re: Crappy day.... how to break the seal on LIM gasket?
    if you have a drilled t stat, its just a 1/8 inch hole in the metal part, those dont need to be bled.
  14. #34 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    JESUS ****ING CHRIST. I knew I should've taken my time with it. I smelled coolant burning so I looked up the installation video. I installed the block rail seals backwards. The rubber/silicone surface is facing outwards instead of inside the block/LIM. What are the chances of salvaging them, will I need another gasket set?
  15. #35 Re: Crappy day.... how to break the seal on LIM gasket?
    you can use the same gaskets again. but the side rubbers my just be ok that way.
    does it run ok? or yet to fire it up?
  16. #36 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    It runs fine but now I'm suspicious of coolant in the oil. It feels rather slick and after driving it it has a sweet smell to it. It could just be the fresh oil in it. If I let it sit for 20-30 mins then it smells like regular oil with blowby in it. I'll change the oil in the morning again to make sure, I picked up 10 quarts of supertech and a cheap filter.
    You're saying the way those seals are facing has no bearing on how well the LIM seals? I understand the block rail seals don't seal coolant ports, I just figured it could be contributing to the problem and wouldn't seal the LIM properly against the rails.
  17. #37 Re: Crappy day.... how to break the seal on LIM gasket?
    Feb 2013
    37.295091, -121.930053
    you could have spilled some coolant on the exhaust and thats why your smelling it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  18. #38 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    Can someone confirm the block rail seals themselves aren't in issue being installed backwards. I can see Scotty's view that it doesn't affect the coolant ports due to location, however I could use the piece of mind.
  19. #39 Re: Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    The other thing that makes me worry is I've added more coolant to the engine since first firing her up. I keep filling it to the top as she was running and eventually it stopped gulping up coolant. I drove it to pick up the oil and when I came back over half of my coolant reservoir had emptied back into the radiator. When I squeeze the upper hose I can hear it sloshing back into the overflow tank.
  20. #40 Re: Crappy day.... how to break the seal on LIM gasket?
    Feb 2013
    thats means you still have air in the system or air is getting in somehow
  1. 3800 rear main seal cover plate gasket orientation
    By Lou and Blue in forum General Tech Discussion
    Last Post: 10-13-2015, 04:28 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
  4. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  5. Diff Housing seal or gasket
    By MnRedGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:18 PM
