Thread: Crappy day.... how to break the seal on LIM gasket?
Results 1 to 20 of 105
Threaded View
  1. #1 Crappy day.... how to break the seal on LIM gasket?
    Banned
    Oct 2015
    Virginia
    So I've had a cold start and idle belt squeak since in installed my rocker arms. After noticing a very slow coolant leak I inspected my old plastic elbows to find that one had broken off in the water pump or lower intake right around the o ring. It was in the lower intake and in the process of retrieving it, it fell inside the lower intake.
    Yay!!! Now I get to replace my lower intake gaskets that are perfectly fine.
    Picked up the gaskets, new aluminum elbows and grey rtv.
    Got everything expect the the egr and lower intake removed in under an hour. Now that damn lower intake manifold is thumbing it's nose at me after eating the broken off piece of elbow. I've yanked on it and beat on it with a plastic deadblow to no avail.
    Any idea to get this little **** to come loose?
    Last edited by TemplesofLamneth; 10-14-2015 at 05:16 PM. Reason: I'm a grammar Nazi
  1. 3800 rear main seal cover plate gasket orientation
    By Lou and Blue in forum General Tech Discussion
    Last Post: 10-13-2015, 04:28 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
  4. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  5. Diff Housing seal or gasket
    By MnRedGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:18 PM
