Thread: Hesitation off idle
Results 1 to 3 of 3
  1. #1 Hesitation off idle
    IL
    Hey guys I just picked up a 98 Grand Prix 3800. I changed the plus and wires, new fuel pump and sender, cleaned maf, new Tps. The engine normally runs great but about one out of ten times when I push the gas from a stop it has no power and doesn't want to go, if I completely let off the gas and hit it again it goes fine. It's definitely in the engine it's not the trains slipping or anything. It seems to bog and miss, any ideas where to look next? There are no check engine codes.
  2. #2 Re: Hesitation off idle
    St. Louis
    Did you clean the entire TB? The backside (the part you can't see) of the butterfly gets really carboned up. What kind of plugs did you use? Change the air and fuel filter?
  3. #3 Re: Hesitation off idle
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i second fordmans77 ideas. clean the throttle body and replace filters. don't just spray crap into the TB , take it off and clean it. don't use throttle body cleaner on the sensors . oh and run some fuel infection cleaner in the gas. i use seafoam
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. 3.1 hesitation on acc. and idle
    By Jody Myers in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-11-2012, 02:16 AM
  3. rough idle hesitation and stalling
    By beast911 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2011, 09:27 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
