So I have 200k on my N/A GP. New wires, coils, fairly new plugs, MAF, MAP, EGR, throttle body cleaned, O2 sensor, air filter.
Its thrown the P0401 and I took it into a shop they said the EGR ports were clear enough. I had disassembled part of the EGR tubes and cleaned them out best I could. Not sure if I've cracked one of the EGR pipes at all?
Could it be a bad CAT? or a clogged one.
I've also been pretty good at using lucas fuel and seafoam on a regular basis and kinda want to swap out my injectors because they're due.
It doesn't run rough or idle poorly, nor am I getting a bad smell on start-up, or anything else that would normally tip me off to the problem.
Let me know what you guys think and what I could tackle next, thanks.
