Thread: New DP Opinions Please
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: New DP Opinions Please
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    if you seafoam the car looking for exhaust leaks you should put new plugs and O2 in after.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #22 Re: New DP Opinions Please
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    No exhaust leak.
    MAF is new.
    Upstream o2 replaced and now it seems that the downstream is not mirroring the up. Still will spike with the up sometimes, but not always. Upstream o2 was fouled up significantly. Going to drive it a bit and see if the pcm is happy. If not then I will replace the downstream o2.
    If its still acting up after that then I need to do the fouler?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #23 Re: New DP Opinions Please
    It's a '97 car.
    It doesn't give two ***ks about a rear o2 or not.
    Just set the code to not report and go about your day.
    Also: I've had a ZZP catted downpipe on my GXP. Just recently had my SLP's installed on it. Got it up in the air...cat was falling apart. No warranty either, and it has 14k~ on it. So, no cat later....car feels a million times better (yes a bit louder) and better MPG's.
  4. #24 Re: New DP Opinions Please
    Newnan, GA
    Rear 02 has now been replaced. Still have to see if the code comes back. The old sensor was fouled and burnt.
    The cat seemed to be solid.
  5. #25 Re: New DP Opinions Please
    Newnan, GA
    6,000 miles later and the light has been off. It was in fact both o2 sensors.
  1. Looking for opinions on what mod to do next
    By GTPguy87 in forum Introductions/Noob Questions
    Last Post: 06-27-2012, 11:05 AM
  2. Opinions on this?
    By mdwstgt in forum Off Topic Discussion
    Last Post: 06-17-2012, 04:09 PM
  3. need opinions..
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 11-04-2010, 01:40 AM
  4. opinions
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-12-2009, 10:14 PM
  5. Mod Opinions
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2009, 06:36 PM
