Thread: 1999 Pontiac Grand Prix Misfire under load
Results 1 to 20 of 20
  1. #1 1999 Pontiac Grand Prix Misfire under load
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    I can't figure out what's causing a random misfire under load in my GP.
    It's the worst when going up a hill, I have to make it shift out of OD and hit about 3k rpms so it doesn't misfire. So any time it hits OD and the load is high, it'll miss HARD. Often times it'll miss with the A/C on at a light, or even idling as well.
    Things I've changed/tried:
    -TB cleaned
    -MAF cleaned
    -Air filter changed
    -Fuel filter changed
    -EGR valve cleaned, then replaced with a different used one
    -Plugs/wires changed (off-brand) might try ACDelco
    -all 3 ignition coils, changed, new
    Perhaps a faulty ignition control module?
    Fuel? I know nothing about fuel systems, so i'd need a pretty lengthy explanation on what to check.
  2. #2 Re: 1999 Pontiac Grand Prix Misfire under load
    What kind of plugs are in there?
    If you think they arent correct, thats the first thing I'd change.
  3. #3 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    NGK TR55
    AUTOLITE Part # 97000 for the wires
  4. #4 Re: 1999 Pontiac Grand Prix Misfire under load
    Do you have a scan tool that can log misfires per cylinder??
    I would even maybe check compression too.
  5. #5 Re: 1999 Pontiac Grand Prix Misfire under load
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Scan tool should help, but it seems like you got most the stuff on the list people would say.
    When i did my plugs and wires, i messed two up, my innovia 3100 abs code reader said this "Generic misfire" No cylinder, nothing else. I swapped the two around and it runs like a top.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  6. #6 Re: 1999 Pontiac Grand Prix Misfire under load
    Howell, NJ
    is it isolated or is it on all cylinders?
  7. #7 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    No idea if it's random.
    There's no code showing up, so idk if a scan tool would help.
  8. #8 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    Quote Originally Posted by Mirraco View Post
    You mean you swapped two wires? I looked over them on the coil install yesterday, but I'll check again. It'd run pretty ****ty if that were the case.
  9. #9 Re: 1999 Pontiac Grand Prix Misfire under load
    St. Louis
    You'd be surprised how well it will run with 2 wires swapped. I did it once and the only thing I could tell is there was a small miss in it at idle, until I drove it that is then it popped the code.
  10. #10 Re: 1999 Pontiac Grand Prix Misfire under load
    IIRC this is a waste fire ignition system so depending on which ones were switched like ford said it wont be as easy to notice.
    Easy things 1st here.
    swap coils around, ex. top one moved to bottom on the icm, middle moved to top, and bottom moved to middle.
    go for a drive does the misfire get any better or worse? drive over to pretty much any local parts store and use scanner, every single one ive ever used says which cylinder is having a miss.
    also these cars usually flash ses light then set it solid for misfires. if its not setting a code like you said then check and make sure the bottoms of the coil packs are clean and not corroded where they sit on the icm.
    also plugs and wires are cheap so if your spending money, plugs and wires 1st.
  11. #11 Re: 1999 Pontiac Grand Prix Misfire under load
    Enfield, CT
    Clean contact points on ICM. Seen crappy connections there on many GM V6s. Also find out if your local NAPA has an ICM tester and if so, ask them to test about 3 or 4 times.
    Sent from my LG G3
  12. #12 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    First off thanks for all the tips and help so far guys, really appreciate it.
    Quote Originally Posted by FordMan77 View Post
    Ok, I looked over them this morning and then I wasn't positive I had the firing order right. It's the same for the S/C version of the series II as it is my version (NA)? Correct?
    Quote Originally Posted by 98bleedingaholevet View Post
    I've done plugs 2x since it started and wires once. I think i'll take it to a mechanic before bothering to change them again. (don't have much free time) It'll run fine for a few drives, then it'll start again. When I swapped the coils with new coils on sunday, it ran fine one trip. It was quite enjoyable.
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    I'm going to check the plug wires to see if they are swapped, then I'll clean the contact points on the ICM and take it in to get it tested at an auto parts store. I called O'Reily's, said they can test most of them.
  13. #13 Re: 1999 Pontiac Grand Prix Misfire under load
    same firing order sc or n/a.
  14. #14 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    The plug connections were all correct.
    I had a code for the MAP sensor come up, I went to "u pull it" and bought a used one, changed that out. We'll see if that changes anything and if it doesn't, I'll start knocking out the rest of the possibilities. Seems to be driving a lot smoother with the acceleration, but I think I still felt a misfire.
  15. #15 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    I went and had the ICM tested, and it was found to be good.
    I cleaned all the contact points and ground surfaces on the ICM, and so far, it's been running a lot better! No codes.
    I didn't spend a lot of time cleaning the part, because i didn't think that was the issue. The misfire has been anywhere from non-existent to a very light and not very noticeable misfire. So I think i'll take it apart again quick and get it under some light to see if there's any spots I missed.
  16. #16 Re: 1999 Pontiac Grand Prix Misfire under load
    icm's test good when bad all the time. add some heat and they act up.
    if need be i got one for sale.
  17. #17 Re: 1999 Pontiac Grand Prix Misfire under load
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    is the misfire always on the same cyl? (code wise) if so, swap coil positions(but move the wires relative to where they are now.) see if it follows the coil...aka misfire moves to a diff cylinder, perhaps pointing to a bad coil pack, or if it stays the same cyl misifre, perhaps the icm.
  18. #18 Re: 1999 Pontiac Grand Prix Misfire under load
    I'm not reading through everything, but if someone hasn't suggested swapping around injectors, I'd do that.
  19. #19 Re: 1999 Pontiac Grand Prix Misfire under load
    Oct 2008
    Omaha, NE
    Quote Originally Posted by ScottyDoggs View Post
    How much? I might just hit the local dump and get one for $15 I think. Easy enough to swap to try it I suppose. The misfire came back btw.
    Quote Originally Posted by JamesIvey24 View Post
    I am not getting any codes, so I don't know.
  20. #20 Re: 1999 Pontiac Grand Prix Misfire under load
    that icm sold already, sorry. junk yard it is.
  1. 1999 pontiac grand prix gt trailer hitch onto 2008 pontiac g5 gt ?
    By thomasd2010 in forum General Grand Prix Discussion
    Last Post: 02-17-2013, 11:47 AM
  2. Cylinder #3 misfire on 1999 Grand Prix GT
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2011, 09:11 PM
  3. 1999 pontiac grand prix
    By stephen in forum Introductions/Noob Questions
    Last Post: 12-29-2009, 03:52 PM
