Thread: Changed all ignition components and have pending Random missfire code.
Results 1 to 16 of 16
  1. #1 Changed all ignition components and have pending Random missfire code.
    GTP Level Member buickman104's Avatar
    NYC
    As the title states I changed all ignition components and have pending Random missfire code. There is really no particular triggers just just the random roughness at idle and a bong from the dash. Then I look at the aeroforce and get the pending code p0300. Other than that the car runs great. Running 1 degree of KR and 14 degrees of timing. Any advice? This only happens at idle.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Changed all ignition components and have pending Random missfire code.
    Set P0300 to no report. Get any misfires after ?
  3. #3 Re: Changed all ignition components and have pending Random missfire code.
    NYC
    Haven't tried that yet. I can feel the missfires in roughness, but only at idle. Think setting it not to report would fix it?
  4. #4 Re: Changed all ignition components and have pending Random missfire code.
    No, but I'd hope that you can find which cylinder or cylinders is causing it.
  5. #5 Re: Changed all ignition components and have pending Random missfire code.
    NYC
    It is completely random sometime cylinder, 3,4,5,6,1,2. completely random
  6. #6 Re: Changed all ignition components and have pending Random missfire code.
    Buffalo
    Can you list the components you changed ex: ICM or coilpacks
  7. #7 Re: Changed all ignition components and have pending Random missfire code.
    NYC
    ICM, coil packs, spark plugs, wires, alternator, battery.
  8. #8 Re: Changed all ignition components and have pending Random missfire code.
    Did you check fuel pressure?
  9. #9 Re: Changed all ignition components and have pending Random missfire code.
    Enfield, CT
    X2. Maybe pumps wearing out or a clogged fuel filter
    Sent from my LG G3
  10. #10 Re: Changed all ignition components and have pending Random missfire code.
    NYC
    I have been through multiple ICMS, and coils. Cleaned all contact points etc. The fuel filter was just changed. This engine has 209,000 miles on it. I have never changed the Crank sensor on it though. It has crossed my mind that maybe the crank sensor might be getting slow in its old age.
  11. #11 Re: Changed all ignition components and have pending Random missfire code.
    NYC
    Not yet. What numbers should I be seeing at idle?
  12. #12 Re: Changed all ignition components and have pending Random missfire code.
    Enfield, CT
    You didn't specify but did you change all ignition parts to try to cure the P0300 and it's still happening? Clean all contact points on ICM.
    Sent from my LG G3
  13. #13 Re: Changed all ignition components and have pending Random missfire code.
    Enfield, CT
    Look here for more info.
    http://www.grandprixforums.net/threa...ble-code-guide
    Also IIRC GM has a TSB out on P0300 codes too.
    Sent from my LG G3
  14. #14 Re: Changed all ignition components and have pending Random missfire code.
    i was getting icm codes and misfire codes,that would come and go when cleared. then i got a crank sensor code. so i changed the crank - cam to icm harness and it was better for a while then it acted up again here and there, then i swapped the motor and used all the same parts but a used crank sensor the used engine came with. been tits since.
  15. #15 Re: Changed all ignition components and have pending Random missfire code.
    mine started to act up at 239,000. so its close to what mine was. the 109,000 mile c/s is working fine now.
  16. #16 Re: Changed all ignition components and have pending Random missfire code.
    Buffalo
    Misfires at idle ? Cam it you can't tell the difference
  1. Replies: 4
    Last Post: 06-05-2015, 03:23 PM
  2. Pending p0128 code today
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2014, 09:28 PM
  3. Has anybody changed the ignition switch
    By 97GPJJ in forum Introductions/Noob Questions
    Last Post: 01-16-2013, 11:11 PM
  4. Changed EPC (PCS) Today! Fixed Code 1811 and Rough Shifts (W/Pictures)
    By dougmac in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2012, 10:30 AM
  5. 01 GrandPrix GT random missfire?
    By Augustine in forum General Tech Discussion
    Last Post: 10-04-2009, 01:06 PM
