Thread: 05 base p0411 help
Results 1 to 6 of 6
  1. #1 05 base p0411 help
    Jan 2013
    United States
    New to forum need expert advice from current gp owners. Failed emissions due to code p0411 air injection system. Changed air pump still have code issue. Don't know what else it could be, and running out of time for registration. Please help if you can.
  2. #2 Re: 05 base p0411 help
    http://www.obd-codes.com/p0411 pretty sure theres a valve that needs to be changed. most delete it and have the codes deleted with a tuner when they can.
    unless your in ca and need to have it.
  3. #3 Re: 05 base p0411 help
    Jan 2013
    United States
    Thanks changed check valve and cleared system. No codes so far but system not ready for air test yet. Evap system not ready.
  4. #4 Re: 05 base p0411 help
    Check wiring and fuses.
  5. #5 Re: 05 base p0411 help
    stuff cant take a day or two to become ready. depends on how much you drive your car.
  6. #6 Re: 05 base p0411 help
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by ScottyDoggs View Post
    This...but there are ways to speed things up a bit.
    http://www.obdii.com/drivecycle.html
  1. P0411 - secondary air flow - Trouble Shooting Help - 06 GP
    By penright in forum General Tech Discussion
    Last Post: 03-20-2014, 03:15 PM
  2. Secondary Air Pump Code P0411 Help
    By hx214 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2013, 09:50 AM
  3. 2007 Grand Prix 3.8l Secondary air injection P0411, P2440, p2431
    By Bumbling fool in forum General Tech Discussion
    Last Post: 03-06-2011, 01:22 PM
  4. P0411 code
    By kevin2502000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 05:50 PM
  5. 2006 Pontiac Grand Prix w/3800 p0411 code
    By rickya in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 09:25 AM
