I bought a 2000 3800 GP a week ago from a guy who took it away from his daughter. Has 177K on it and bought it for $375, It started right up and drove on the trailer. He had cut the Cat off it for Scrap, so when I got it home I put a piece of pipe on it and unplugged the 02 sensor that goes behind the cat. It ran and drove good for several days and put about 40 miles on it with no problems, until yesterday.
I filled the car full of gas and it started to rain out and I drove it 7 or 8 blocks in the rain and started running ruff/cutting out and died, it would refire but acted like it was flooding itself out when I would push on the gas and would run briefly and die. I let it sit a day, started it up and it idled fine for a couple minutes, but when I put it in gear it would die/ cut out, same as when I pushed on the throttle.
Could this be a bad Throttle position sensor?
Or is it caused by not having the cat and the sensor unplugged? I had a 96 3100 GP that I cut the cat off and replaced with a pipe and unhooked the 02 sensor and drove it 4 years without a problem, I also had a couple 97-2001 GTP's that I cut the cats and exhaust off and raced on dirt and never had a problem.
Or could it be something else?
