ok you have alot of questions there with not clean cut answers. first 1.8 rockers will do better on the NA motor. second valve retainer is based on install heigh and valve spring size. if you are using the 105 springs you should use the ls based retainers you can however use the stock locks.
best bet if to post up what you want to use and someone will helexplain why it will or wont work.
