Thread: car just killed on me while driving
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 142
  1. #41 Re: car just killed on me while driving
    Feb 2013
    37.295091, -121.930053
    did you follow this video?
    https://youtu.be/40VN5j1xc3A
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  2. #42 Re: car just killed on me while driving
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Yea but he didn't replace his harmonic balancer
  3. #43 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Do i have to insert the woodruff key inside my harmonic balancer for it to start?
  4. #44 Re: car just killed on me while driving
    wait a minute.....you didnt put the key back in the slot in the crank?
    if you did was it lined up with the balancer?
  5. #45 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    I just put the balancer pulley on I didn't know what the key was for or where it went
  6. #46 Re: car just killed on me while driving
    damn. take it back off again. then put the key in the slot in the crank, then line up the groove in the balancer and put it back on.
    if need be you can turn the engine so the key is facing up/ the top side of the crank.
  7. #47 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Yea I'm going to have a real hard time getting the bolt off now since my car won't start this time
  8. #48 Re: car just killed on me while driving
    GT Level Member Xorbex's Avatar
    Canada
    there should have been a key in your crank. when you put the pulley back on theres a slot in the pulley that lines up with the key on the crank. ensure you did this properly or there will be major issues
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  9. #49 Re: car just killed on me while driving
    St. Louis
    I said this in post #12. If you didn't line up the existing woodruff key in the crankshaft with the balancer then your motor timing could be off. Stick a vice-grip on the flexplate to keep the motor from turning and pull the crank bolt back out and be sure you have the balancer lined up with the key.
  10. #50 Re: car just killed on me while driving
    you can still do the red neck starter bolt deal if need be, as long as the engine will crank over, its the starter that undoes the bolt.
  11. #51 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    The Flexplate is the flywheel right?
  12. #52 Re: car just killed on me while driving
    yup
  13. #53 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Where do the key go??
  14. #54 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Insert it like this?
  15. #55 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Like this?
  16. #56 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Or like this
  17. #57 Re: car just killed on me while driving
    Feb 2013
    Missouri
    It should fit into the crank, kinda like you have in the second pic.
  18. #58 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Please tell me this is the right way?
  19. #59 Re: car just killed on me while driving
    Feb 2013
    Missouri
    It goes into the crank, not the harmonic balancer.....Well, this is not a pic of a 3800, but this is the general idea:
  20. #60 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Isn't that it on the side?
  1. Got killed.....well could have
    By 98L36 in forum Track Sessions and Kills
    Last Post: 09-14-2011, 12:00 AM
  2. 2 stangs, killed and got killed
    By Boosted02GTP in forum Track Sessions and Kills
    Last Post: 10-30-2010, 08:28 PM
  3. killed
    By Standby in forum Track Sessions and Kills
    Last Post: 07-16-2009, 10:45 AM
  4. I got killed....
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 04-19-2009, 08:20 PM
  5. I got killed
    By TDCRacing in forum Track Sessions and Kills
    Last Post: 08-02-2008, 04:54 PM
