should i replace the whole harmonic balancer?
Find a deepwell socket that will fit into the crank where the bolt was. As long as it is enough to bottom out IN the crank then you thread the remover in until it hits the top of the socket sticking out and crank away. Balancer should pop off.
Also, judging by that last pic it looks like your motor mount is trashed. Might be a good time to replace it since you are right there.
That would probably be a better bet.
OP- Whatever way you can get the holes of the remover to line up. Doesn't matter on the position of the remover.
Replace the motor mount so your axle geometry is back where it should be and your motor isn't rocking around in the bay?
