The filter did break off
This ^^^^^^^^
Dorman pan..30bucls
yeah dude you should do the shift kit. I did it last friday. Literally takes about half an hour more work than just fluid and filter. It's just like 3 springs and 6 shims. If you have to order a pan, order that shift kit too. Your trans will thank you, shifting fine now or not..
Then add a cooler, install this kit, run Dex VI fluid, get a tune, and add a bottle of Lubeguard red. Your transmission will thank you and live a long life...for a stockish engine. Unless you have something older than 03, then you might have problems with overdrive eventually.
All 97 na motors got the 4t60e...best way to see if it was upgraded is to see if there is a vacuum line that goes from the throttle body to the front of the trans (vacuum modulator)..if so you got a 60.
