Thread: Corroded LIM Lower intake manifold Get new manifold or is this one ok
Results 1 to 11 of 11
  1. #1 Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Aug 2012
    MI
    Quick question, do not want to do this twice Replacing the lower intake gasket for my dad. Is this lower still usable or would you replace it too?
    http://i.picresize.com/E8Av
    http://i.picresize.com/E8AJ
  2. #2 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    That looks like a coolant port that is blocked.
  3. #3 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    isn't one lim port blocked off?
  4. #4 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Aug 2012
    MI
    Pics from further away corroded spot should be smooth.
    http://i.picresize.com/E8EA
    http://i.picresize.com/E8EE
    My thoughts are to get another lower manifold.
  5. #5 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Aug 2012
    MI
    160,000 miles on the original gasket.
    http://i.picresize.com/E8E3
    http://i.picresize.com/E8EH
  6. #6 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    that port comes sealed off like that, as long as the gasket is around that rotted area it should be ok.
  7. #7 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Aug 2012
    MI
    Gasket is sitting partly on the rotted area.
  8. #8 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    maybe time for a another lim then. you dont need any leaks after its done.
  9. #9 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You can buy a used LIM pretty cheap. I'd just snag another one.
  10. #10 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Too cheap to not replace, not worth risking your motor for $100 or less. Ebay has good prices.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  11. #11 Re: Corroded LIM Lower intake manifold Get new manifold or is this one ok
    Aug 2012
    MI
    Advice taken. Just bought a lower intake from one of the forum members here.
    Thanks again.
  1. Lower Intake Manifold
    By Badgers4life in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-16-2013, 09:28 AM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  4. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
