I would think it would if the crank sensor was causing it to misfire. But I would think you would see some 300 codes. If this happened after you replaced the tstat I would be looking in that area for a loose connector or pinched wire. If you do decide to do the crank sensor you should think about the cam sensor while you’re in there. Good luck let us know how it turns out.
