Thread: Good daily cam??
Results 1 to 20 of 23
  1. #1 Good daily cam??
    Jan 2015
    Michigan
    hey does anyone have a cammed gt that is a daily driver? I want to cam my gt but i have to drive it for school and work and dont want it to over heat. any suggestions on a mild cam?
  2. #2 Re: Good daily cam??
    The Boss Iceman6669's Avatar
    Jun 2011
    https://www.youtube.com/watch?v=MzoaMzgpm9A
    Thats a GT1 cam. And yes it can be DD
    2011 F-150 Yote powered
  3. #3 Re: Good daily cam??
    Jan 2015
    Michigan
    Thanks! would it still work well if i decided to top swap my gt?
  4. #4 Re: Good daily cam??
    Jun 2011
    The car in that video IS actually top swapped.
  5. #5 Re: Good daily cam??
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    If your going to topswap, go xp or similar.It can be dd.Its the step before xpz.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  6. #6 Re: Good daily cam??
    S1X cam in my daily!! Very nice cam for a DD imo nothing insane but on e85 makes 330whp. Pretty decent imo especially since that's WITHOUT an intercooler!
  7. #7 Re: Good daily cam??
    Feb 2014
    Ky
    Would slicks s1x na cam work well if he planned on staying na?
  8. #8 Re: Good daily cam??
    Yes I cant believe that S1X na cam is still forsale!
    Someone needs to grab that S1X cam from Slick and throw this on it too!
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    Id rock that S1X cam on a NA car over the GT1 cam any day.
    Ive always wanted to see what a cammed NA car with some 3.69 gears and a 75 or 100 shot would do!
    (ive got some 3.69 gears and a zex nitrous kit I'd sell too just sayin........)
  9. #9 Re: Good daily cam??
  10. #10 Re: Good daily cam??
    Feb 2014
    Ky
    That would work as well Id be curious to see what kinda power it would make.
  11. #11 Re: Good daily cam??
    all of them. it's an automatic.
    dafuk does trans have to do with cam choice in a wbody? Glad you pointed out its an automatic in the wbody...........
  12. #12 Re: Good daily cam??
    you can have the biggest cam in the world in an automatic without having driveability issues.
    a huge cam in a manual car makes it a bit harder to drive in heavy traffic...
  13. #13 Re: Good daily cam??
    Again glad you pointed out that the wbody has and automatic.........
    no need for the reply we all know you drive a manual rwd car and again who cares that's not fwd or auto........
    Or maybe to run a big cam in a rwd manual car you could set up the car with a clutch combo that was worth a sh1t..........
    Don't tell me it cant be done, mustang Camaros ect ect ect all do it.
    Again no need here for a response I thought this thread was about a cammed AUTO FWD WBODY?
  14. #14 Re: Good daily cam??
    May 2008
    Schuyler, NE
    If I were you, I wouldn't spend the money to cam a na motor. There is not much for gains. These motors make power with boost. Most other mods don't do much in the grand scheme of things.
    If you think you will top swap it, I would save up for some heads and stick in an xpz at the same time. IMO, the xpz is a better dd cam than the xp.
  15. #15 Re: Good daily cam??
    Kemmerer, Wyoming
    an aggressive N/A cam build with heads is only going to put about 240 hp at the wheels, if that. you are better off adding a supercharger or a turbo and installing an xp or xpz cam. its more work, but a lot more power.
  16. #16 Re: Good daily cam??
    Get a radiator flush and make sure your T-Stat is working and your tune that you'll be getting has the fan turn on point lower than stock. That'll keep it cool. How does a different camshaft profile make a car get hot?
    Plugs/wires/t-stat, HV3, 3" DP/PLOG, Tune, Intake, Solid Mounts, ER Rockers, different mufflers.
    Will make around 200~WHP and should run decently close to a stock GTP. Been there, done that.
    Quote Originally Posted by SgtMarshal View Post
    I enjoy the broad range of everything you just suggested.
    JUST DO EVERYTHING TO IT. IT'LL BE FASTER.
  17. #17 Re: Good daily cam??
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Quote Originally Posted by blueguy View Post
    Also a good setup to hit the ground running with a turbo later down the road.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  18. #18 Re: Good daily cam??
    Donating Users Uno99's Avatar
    Appleton, Wi
    I say used the money for the planned na cam and put it towards the parts for topswap.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  19. #19 Re: Good daily cam??
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Quote Originally Posted by 98ICLovinVet View Post
    (ive got some 3.69 gears for sale
    how much?
  20. #20 Re: Good daily cam??
    Or just save your money for a complete turbo setup.
    And don't waste it on anything else.
  1. Daily Drivers?
    By Taz Magister in forum General Tech Discussion
    Last Post: 07-08-2011, 12:19 PM
  2. My daily conversation.
    By ZR1Vette09 in forum The Rant Forum
    Last Post: 03-21-2011, 10:03 PM
  3. 2000 GT Daily Driver
    By MBruneaux in forum Introductions/Noob Questions
    Last Post: 03-06-2010, 08:43 PM
  4. Daily B!tch!ng : RANT AWAY!
    By singularity in forum The Rant Forum
    Last Post: 09-06-2009, 02:52 PM
  5. gs-t for a daily driver
    By turbotooslow in forum Off Topic Discussion
    Last Post: 10-04-2008, 04:11 AM
