Thread: Intermittent EGR Code, EGR valve replaced
Results 1 to 7 of 7
  1. #1 Intermittent EGR Code, EGR valve replaced
    May 2012
    Bloomington, IN
    Have an '04 N/A with 191k. So far I've replaced the PCV valve and MAP sensor as I was getting some bad mileage. Got an EGR code for insufficient flow. Replaced the valve and cleaned the MAF. I had also cleaned out the throttle body around 145k along with swapping out the upstream O2 sensor. I'm now getting an EGR code every now and then. I did not clean out the EGR pipe which goes to the intake. Not sure if this would be the culprit, or if just replacing it would be easier than trying to clean it. I tried some throttle body cleaner on the old EGR valve but nothing really came out. I haven't tried SeaFoam on anything, not sure if that's a better means of cleaning it out.
    I've also read that the rubber O-ring around the PCV might be a problem as the PCV-MAP sensor-EGR combo can throw codes sometimes. I did not change out this O-ring.
    Let me know if anyone else has had some similar issues or solutions, thanks.
  2. #2 Re: Intermittent EGR Code, EGR valve replaced
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I don't imagine removing the EGR is an option for you?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  3. #3 Re: Intermittent EGR Code, EGR valve replaced
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Whats the code?
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Intermittent EGR Code, EGR valve replaced
    May 2012
    Bloomington, IN
    p0401
  5. #5 Re: Intermittent EGR Code, EGR valve replaced
    pull the tubes off and make sure they are not clogged up. try not to flex them to much.
    also check the wires to the egr plug, they could be damaged in some way. missing insulation or cracks can kill a wire.
  6. #6 Re: Intermittent EGR Code, EGR valve replaced
    Oct 2014
    portland oregon
    I have the same code i thought it was tuned out. my exaust and lim are blocked off. Car is running great tho
  7. #7 Re: Intermittent EGR Code, EGR valve replaced
    Kemmerer, Wyoming
    the problem with egr codes is that there are causes other than the egr.
  1. Replies: 10
    Last Post: 01-02-2014, 10:37 PM
  2. Replaced EGR valve and gasket, SES still on
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-08-2012, 11:08 AM
  3. P0101 MAF...Replaced and still throwing code HELP!
    By silver86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 01:35 PM
  4. Intermittent P0171 code
    By mwzeigler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2011, 06:10 AM
  5. Noisy valve train intermittent oil pressure
    By Rico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 06:50 AM
