Thread: Burning coolant?
Results 1 to 11 of 11
  1. #1 Burning coolant?
    A friend of mine bought a 2000 Impala with the n/a 3.8 and it is burning coolant pretty bad. My friend was telling me that when he took off the radiator cap he could smell an exhaust smell after he opened it. I am guessing that it might have a blown out head gasket but I am not 100% sure on that. Just thought I would see what you all thought it might be.
  2. #2 Re: Burning coolant?
    rad cap off, rev the engine watch inside the rad for bubbles after you let off the gas.
    they sell a test kit, it goes on the rad in place of the cap. if the fluid changes color theres o2 gasses in the coolant.
  3. #3 Re: Burning coolant?
    Have him pop the TB. Most likely you'll see that right inside the UIM where the EGR tube comes up has a lot of moisture around it. This would mean the UIM has cracked and is allowing coolant into the intake.
  4. #4 Re: Burning coolant?
    This was another thing I was thinking is wrong.
    Maybe you should tell 98grandprickvet that the l36 upper intake is garbage and prone to cracking. Because according to him they never crack.
  5. #5 Re: Burning coolant?
    Quote Originally Posted by Slick2500 View Post
    Arguing with Tyler is less satisfying than banging my head on a concrete wall.
  6. #6 Re: Burning coolant?
    Enfield, CT
    x2.
  7. #7 Re: Burning coolant?
    True Story
  8. #8 Re: Burning coolant?
    The car is dumping coolant so fast that the radiator won't fill and then the engine Vapor locked.
  9. #9 Re: Burning coolant?
    so stick a fork in it, its done?
  10. #10 Re: Burning coolant?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    If it's not too late to save it, I highly recommend plugging the LIM using Bill's tap/plug method. Did that to my 2004 while doing the LIM gaskets... saved me from buying a new UIM and no more worries.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  11. #11 Re: Burning coolant?
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    can you explain plug and tap? sounds useful
  1. Burning coolant? Brown sludge in radiator
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2013, 04:22 PM
  2. Burning oil
    By Anthony Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2013, 04:32 PM
  3. burning coolant:( smokes when i shut it down
    By gtcoup in forum General Tech Discussion
    Last Post: 01-31-2011, 12:08 PM
  4. My Car Is Burning Hot Lately
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 12:16 PM
  5. Oil Burning
    By 3rdpontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2010, 09:23 PM
