Thread: Which coolant to use...
Results 1 to 16 of 16
  1. #1 Which coolant to use...
    SE Level Member Rickochet's Avatar
    Dec 2008
    Indiana
    This has probably been debated many, many times, but what is the latest consensus on which type of coolant to use after replacing lower intake gaskets and flushing the cooling system. Some say Dexcool due to the chemical make up and incompatibility of other brands of coolant and some say use Prestone or what ever brand. I plan to keep this car for a long time and I really prefer to not have coolant related issues if there is a way to avoid them. Thanks in advance for the info!
    Rick
    "It usually takes less time to do something right the first time than it takes to explain why you didn't!"
  2. #2 Re: Which coolant to use...
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You can search, and find tons of information on it. I recommend the yellow stuff.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Which coolant to use...
    Oklahoma
  4. #4 Re: Which coolant to use...
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^ word!
    if you can, have a shop flush ALLLLLLL the dexclog out, and put in normal!
  5. #5 Re: Which coolant to use...
    TDCRacing
    Guest
    Anything but dexcool.
  6. #6 Re: Which coolant to use...
    SE Level Member $03gp/gt$'s Avatar
    Feb 2008
    Chillicothe/Peoria IL
    dexcool is junk I would roll with the Green Stuff for sure
  7. #7 Re: Which coolant to use...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    No question, G-05 spec coolant (Zerex, Ford Gold, new Crysler stuff)
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Which coolant to use...
    Aug 2008
    Flushing/Flint, MI
    green coolant</thead>
  9. #9 Re: Which coolant to use...
    Barksdale AFB, LA
    Nothing wrong with Dexcool if you maintain your coolant system. Still, I've been putting the yellow back in as needed. Though I'm in no rush to remove any remaining Dex. 72k miles and no cooling system problems.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Which coolant to use...
    Aug 2008
    Flushing/Flint, MI
    Quote Originally Posted by Sabrewings View Post
    If you dident have dexcool you wouldnt have the need to keep adding the yellow as needed, when it leaks.
  11. #11 Re: Which coolant to use...
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Dexcool will sludge if air is introduced to the system.
    Dex likes to eat plastic gaskets.
    Dex runs warmer in most cases, once I switched to green on the prix and the regal both cars ran 10degrees cooler.
    In the summer time I'm going to try just water and water wetter
    Edited for Sex runs warmer. Posted from ipod. Still getting used to touch keypad(fat figers)
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  12. #12 Re: Which coolant to use...
    Oklahoma
    Quote Originally Posted by Toofastgs View Post
    It isnt the Dex-Cool itself that eats plastic gaskets. That affect seems to come more from the sludge that is created that tends to solidify over time and becomes some what abrasive. Its not the coolant itself, its the affect of the coolant being exposed to air.
  13. #13 Re: Which coolant to use...
    QCA, IA
    Sex runs warmer in most cases
    must...resist....comment....
    Does water wetter have any anti-corrosives in it? If not, I sure wouldn't recommend running without any coolant, you would have the same problems you can get with Dex and air destroying the anti-corrosives.
  14. #14 Re: Which coolant to use...
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    i run AMSOIL yellow coolant, it is compatible with everything. as a GM tech Ive seen the results of dex cool first hand, dex cool will become sludgy if not maintained. if you add green to the orange it tunrs into a brownish gelatin substance that will clog up everything. i stay away from dex cool only because ive found myself in a bind where i had a leak and coolant was low and found myself at the closest gas stations and stores and nobody carried dex cool. this happened at 5:30 am on my way to work needless to say there was auto parts stores open, but i did manage by using plain ol' water for the time being. a real nightmare though trying to find dex outside of a shop or auto house
    COMP G
  15. #15 Re: Which coolant to use...
    Barksdale AFB, LA
    Quote Originally Posted by Dawings33 View Post
    My system is not leaking at all, thank you very much. As needed would be when I tear into it to for upgrades (removed throttle body, changing thermostats, changing coolant elbows, etc). My car doesn't leak a drip since I replaced the original ****ty LIM gaskets.
  16. #16 Re: Which coolant to use...
    Donating Users WackyWRZ's Avatar
    Omaha, Nebraska
    I believe that the 5.7L Vortec motor (late 90s) also had intake leak problems as well. Have put 2 into my old mans truck (2000 K2500) and 1 into my brothers 97 K2500!
  1. How many people still use Dex Coolant
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 02-20-2009, 09:17 PM
  2. coolant recovery?
    By 98GPGT in forum General Tech Discussion
    Last Post: 12-17-2008, 11:00 AM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
