2005 GP with Gen3 3800 @ 170k mi. It uses 1 qt. of oil every 3k mi. since about 100k. I JUST replaced the LIM due to failure, but I have done the water pump and coolant elbows a few times in the last few years. Everything FINALLY looks good to go with the coolant system, but the damn thing still smells like coolant. Hope there isn't a small head gasket leak or something.
Anyway, last year I replaced the upstream O2 sensor with a Bosch along with NGK iridiums and quality wires as part of regular maintenance. It ran perfect for about 6 mo., then I got a CEL that indicated an O2 sensor issue, though I don't recall the exact code. I'm almost positive it pointed to the front sensor as I sent the "new" O2 sensor back to O'Reilly via my wife for a replacement and they stated that they couldn't find that p/n associated with any similar GM vehicles. Not sure where they pulled it out of their butt from last time, but they sent home a different Bosch sensor. After coming up empty handed on the internets, I called Bosch and had them confirm the part number issue, and again I don't really recall the specifics, (it's been a crazy year for motorcycle, vehicle, and home maintenance) but I THINK they were generally worthless. It was enough encouragement to go ahead and use this new p/n, however. I'm not one to just throw the wrong part in, so I must have been satisfied with this sensor when I last slapped it in.
Well, that was about 6 mo. ago and today it threw a P0420 Bank 1. I either have the wrong sensor again, something it making it fail every 6 mo., the downstream sensor now needs replaced, or that 1 qt. of oil every 3k mi. has finally damaged the cat and or sensor. I run a can of Seafoam through the brake booster line every 50k or so, and 1 can in the gas tank every 20k or so. I JUST did this process via brake booster about 4k mi. ago along with the LIM.
I'm thinking about replacing the downstream sensor and going from there but wanted to run this issue by you guys. I'm not even positive which bank is 1 and which is 0, or 2.
