Thread: is it even worth moding my '97 GT
Results 1 to 16 of 16
  1. #1 is it even worth moding my '97 GT
    SE Level Member thisguy963's Avatar
    Jan 2015
    CA
    I have a 97 Grand prix with 139k miles, and I want to know if it's even worth putting any money into it. I was looking at cat back, cold air intakes, headers, preformance PCM, MSD wires and coils, ect, but I'm not sure if it's even worth it, any advice?
  2. #2 Re: is it even worth moding my '97 GT
    Aug 2013
    McDonald PA
    Suspension mods a diy intAke and you can change muffs and tips if you want other than that unless you wanna top swap I don't recommend it
  3. #3 Re: is it even worth moding my '97 GT
    St. Louis
    Tell us what your goals and budget are for your ride. Once we know that then we can suggest some good mods.
    Cat-back will do nothing for you. Stock exhaust is good up to around 350hp. Leave it be. And no, don't put Flowmasters or anything on it. It will not sound like a V8, not now, not ever. Headers and tune may net you a bit. Leave the "My Spark Disappeared" coils off and stick with OEM as the OEM are much better. If you must, then paint the stockers red. Run stock IRRIDIUM plugs (not platinums) and the lifetime wires from Autozone. No need to go big here.
    Assuming all the suspension is up to date and the LIM gaskets have been replaced you should be good to go. If you really want to make it faster then turbo time. For the time/money invested even a S/C top swap doesn't net more HP. And the fact that you have a 97 makes it a bit more challenging. Either way you would also need a built trans. if you go this route.
  4. #4 Re: is it even worth moding my '97 GT
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Speaking from experience, I suggest to go upgrading the handling instead of power. Suspension parts are generally easier to remove later when you move on to a GTP.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: is it even worth moding my '97 GT
    Quote Originally Posted by thisguy963 View Post
    all that stuff is kinda worthless on a n/a engine. but needed if you top swap or turbo it.
  6. #6 Re: is it even worth moding my '97 GT
    Jan 2015
    CA
    FordMan77, my budget is max like $650 right now. And my goal is to make my car more fun to drive, and maybe crank out some more powe,r if possible.
  7. #7 Re: is it even worth moding my '97 GT
    Aug 2013
    McDonald PA
    Pm dsmuts he has a 97-03 top swap forsale you just need the blower
  8. #8 Re: is it even worth moding my '97 GT
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    That 4t60 is your limiting factor on power, I personally would focus on handling like EJOUIE said.That trans will hate you if you start adding power.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  9. #9 Re: is it even worth moding my '97 GT
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Quote Originally Posted by EJOUIE View Post
    This is exactly what I've done with my 98 GT. Suspension, appearance, and exhaust. I did an intake just because but that's it really for performance.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  10. #10 Re: is it even worth moding my '97 GT
    Feb 2010
    TN
    For fun to drive STB's front and rear. heavier sways front and rear. F-body calipers Digital dic CAI. Junkyard will save you lots of money on those.
  11. #11 Re: is it even worth moding my '97 GT
    St. Louis
    For the brake upgrade you could also snag the 06+ Impala front rotors and calipers/brackets. Same as the F-bodys, but iron caliper vs/ aluminum, and depending on the JY you get them from they are usually cheaper since most yards want more $$ for a Camaro/Firebird part than an regular old Impala. As long as you get the stock bolts with the brakes then they will bolt right up to your existing knuckle, no adapter or sleeves needed.
  12. #12 Re: is it even worth moding my '97 GT
    The vacuum powered super awesomely weak link of a transmission that only the N/A '97 GT's got...sucks.
    If you don't plan on tossing at least a decent trans in it, don't bother with modding it.
    Find another car or get a built trans.
    New solid lower mounts, Poly Uppers mounts, Solid sways with poly bushings, Aftermarket trailing arms, 180* T-stat, get that PCM tuned, have the u-bend deleted and toss a high flow filter in it. Past that, STB's (which really don't make much of a difference), struts/springs/wheel-tire combo will pull everything together.
  13. #13 Re: is it even worth moding my '97 GT
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    My 60E took some pretty good abuse, would chirp the tires on the 1-2 shift, and break them loose going wot at 50. Granted it never saw anything but street tires at the track, and I kept the fluid fresh in it, but I would romp on it pretty regularly, especially while scanning trying to get the tune dialed in. I don't think anything n/a will break it unless you're trying to, low 15's/high 14's would be fine if that's all you're looking for in it.
  14. #14 Re: is it even worth moding my '97 GT
    I break stuff selliott's Avatar
    Kansas City
    Quote Originally Posted by blueguy View Post
    This ^^ Ive had plenty of issues with those stupid vacuum lines in my old 97 gt.
  15. #15 Re: is it even worth moding my '97 GT
    Jan 2015
    CA
    can i replace the vacuum lines to prevent any issues or would the entire trans need to be rebuilt?
  16. #16 Re: is it even worth moding my '97 GT
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  1. Stock 04 Fuel Rails - perfect for a core return or self moding
    By ADrugDealer in forum For Sale - Parts
    Last Post: 08-16-2013, 11:20 AM
  2. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
  3. what do i have here and what is it worth
    By 2002gtx in forum Off Topic Discussion
    Last Post: 03-02-2011, 06:11 PM
  4. Is the job really worth it?
    By Vegas_Matt in forum The Rant Forum
    Last Post: 01-31-2011, 11:10 PM
  5. Is it worth it?
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 11-07-2009, 04:18 PM
