So the night before I added half quart of oil I was low on and the next morning I start the car and engine light turns on and get these 2 codes. Probably unrelated to the oil but weird it happened. Any insight on these codes? Can't find them on here
DTC P1811 Maximum Adapt and Long Shift
Here is TEPs explanation on the P1811 http://www.tripleedgeperformance.com...ift-P1811.html
P0496 on obd-codes.com lists it as "Evap Flow During Non-Purge Condition" weird this one isnt in my pdf of obd codes.
Thanks for the info on the transmission one will look more into that.and the P0496 I can't really find anything on I think I'm just going to replace the canister purge valve or vent valve solenoid and see what happens with that one.
Did you fix the p0496 code? If so what did you do? I have it now.
https://www.obd-codes.com/p0496 id start with the canister tank and its parts to and from it.
