Thread: Abs/trac light
Results 1 to 14 of 14
  1. #1 Abs/trac light
    Dec 2014
    Indiana
    Wondering if anyone can help my 05 grand Prix abs light and traction control light turns on after driving a couple of minutes or hitting a bump if I turn it off it goes off until I drive it again I searched on here about a bad wheel speed sensor but the light should be on right from the start correct? Mine goes on during driving. Stopped at auto zone to see if they could scan but said they don't do abs lights...what could be the problem don't have too much knowledge with these
  2. #2 Re: Abs/trac light
    Loose/bad connector somewhere.
  3. #3 Re: Abs/trac light
    Dec 2014
    Indiana
    From the hub or the wiring harness itself? None of the wires look broken to mw
  4. #4 Re: Abs/trac light
    Could be both, my car did that for a while then it just came on all the time, looked under the car and noticed that the wires had pulled out of the hub itself.
  5. #5 Re: Abs/trac light
    Dec 2014
    Indiana
    I'll check In the morning for wires underneath. And is there a way to check which hub is bad if that does happen to be the problem?can you scan abs codes while car is on?sorry for all questions
  6. #6 Re: Abs/trac light
    jack each wheel up, lugs tight grab the top of the tire and push then pull firmly, if you feel play you have a bad hub, bad hub makes the sensor thats built into it not work right. hitting a bump will set the abs light off.
    if you cant find a loose hub/wire or damaged wires get it scanned. no sense in tossing money at guesses.
  7. #7 Re: Abs/trac light
    Iirc you need an abs scanner.
  8. #8 Re: Abs/trac light
    SWPA
    Quote Originally Posted by Slick2500 View Post
    Not necessarily. The OBD2 code reader I used at Advance Auto told me where my issue laid when I was having similar issues.
    Mine was a loose/frayed wire. I replaced the harness from the hub to about 3 feet back as it was corroded a good way back.
  9. #9 Re: Abs/trac light
    Dec 2014
    Indiana
    Alright thanks everyone I'll see what I can figure out tomorrow checking the hubs and inspecting the harness as far back as possible.
  10. #10 Re: Abs/trac light
    Dec 2014
    Indiana
    Are there also any places that can scan the light for me before I have to pay at a shop to have it scanned
  11. #11 Re: Abs/trac light
    you'll have to pay at a shop if the autozone scanner dont pull up a abs code, some newer cars the normal scanner can pick up abs.
  12. #12 Re: Abs/trac light
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've been able to read ABS codes with HPT, if you know someone local who has it.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #13 Re: Abs/trac light
    Canada
    A good place to check the abs wire is right at the first bend off the hub...usually on the lca....thats the most common place they corrode or break. On mine the wire was pretty much broke on the first bend , but by just looking at the wire you could not tell until you tried to bend it back and forth then I could tell the wire was bad as it was so flimsy(if that makes sense).....hope this helps ya some
  14. #14 Re: Abs/trac light
    May 2012
    Bloomington, IN
    Also, you might want to see if in fact it is the abs sensor and not the abs control unit. The units are prone to failure because instead of soldering the connections they use sound or ultrasonic means to make electrical connections which are prone to failure given age or mileage.
    http://www.grandprixforums.net/threa...18#post1173518
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. abs light on, trac ctrl light off, what does this mean?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 03:04 PM
  3. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
