Thread: Transmission pan drain plug 3800 v6
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Transmission pan drain plug 3800 v6
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Can anyone tell me what kind of screw or plug can I plug into my transmission pan because my original rubber plug had a hole in it and leaked out all my transmission fluid
  2. #2 Re: Transmission pan drain plug 3800 v6
    Jan 2014
    AR
    They don't have a drain plug from the factory and this is why. They leak. You could get another pan and put it back original or maybe try to put a better drain plug in a salvage pan and then swap. Or re-do what you have. Any option involves removing the pan.
  3. #3 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
    I'm not trying to remove the whole pan can I just buy a steel screw from somewhere to replace the rubber plug?
  4. #4 Re: Transmission pan drain plug 3800 v6
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Do you have a picture of your current pan so we can get an idea of what you got?
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  6. #6 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  7. #7 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  8. #8 Re: Transmission pan drain plug 3800 v6
    Feb 2013
    Missouri
    Was that a junkyard transmission or pan? That's a hole. Not a plug. You're gonna need a new pan.
  9. #9 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
    I took the rubber plug out it was where the transmission fluid is leaking I'm asking can I get a screw to replace it
  10. #10 Re: Transmission pan drain plug 3800 v6
    Feb 2013
    Missouri
    No. You need a new pan. Junkyards are required by law to drain transmissions when they get them, and they poke holes just like that, an put a rubber plug in them. That shouldn't be there at all. You need a new pan.
  11. #11 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
    Yea I did get that pan from the junkyard
  12. #12 Re: Transmission pan drain plug 3800 v6
    Feb 2013
    Missouri
    That's the problem. Dorman sells a replacement pan that has a drain plug pre-installed.
  13. #13 Re: Transmission pan drain plug 3800 v6
    Apr 2012
    Dayton, OH
    Dorman makes a replacement pan with a drainplug in it for like 30 bucks if that interests you. I imagine you could find a stocker cheap somewhere tho.
    2012 F150 STX
  14. #14 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
    Ok what if the bolts around my transmission pan is 10 mm
  15. #15 Re: Transmission pan drain plug 3800 v6
    Jan 2014
    AR
    Quote Originally Posted by Jason97GrandprixGT View Post
    This is normal, isn't it? I mean aren't they all? Someone could have tapped the trans body and used oversized bolts if those are supposed to be 8mm but got stripped out at some point.
  16. #16 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
    Ok I got my pan off and try to take the filter out to but the filter part that plug in the transmission broke off. What should I do
  17. #17 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  18. #18 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  19. #19 Re: Transmission pan drain plug 3800 v6
    Sep 2014
    New Orleans
  20. #20 Re: Transmission pan drain plug 3800 v6
    Jan 2014
    AR
    I think it might just be the filter that broke. Don't think i have one here to look at though.
  1. Oil drain plug size
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2012, 12:54 PM
  2. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  3. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  4. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
  5. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
