Swap the flex as well. The LeSlopper should have a 258mm TC pattern flex, the GP will have a 245mm.
If you want to turn it over. pull all the plugs and let the water out. Your upper intake manifold probably let go. See the link below for the info and possibly saving your current engine.
http://www.grandprixforums.net/threa...hlight=failure
