Thread: best motor mount
Results 1 to 20 of 33
  1. #1 best motor mount
    Nov 2014
    winston salem,nc
    ihave a 98 gp 3.8 n/a i was doing body work today and had the hood up and noticed the motor wasnt sitting wright, grabed the motor and it moved foward about 4 inchs very easy, the car is a daily driver, stock for now and stock hight, what mounts should i go with? and i read the shorter wish bones will increase oil pressure some how, should i go with them?
  2. #2 Re: best motor mount
    Any new motor mount will do. Most of us prefer a solid rubber mount instead of a fluid filled mount. Autozone or advanced sells them I think.
    And moving the motor forward can't increase oil pressure. Stop and think about it in real life for a second, how can the placement of a motor make a mechanical part any more efficient. The pick up tube will always be under oil and thats all it needs.
  3. #3 Re: best motor mount
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I have lower motor mounts to do as well. Do you have specific part numbers for mounts that are actual solid rubber? I keep reading about people buying mounts advertised as solid, but were actually fluid filled or hollow.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: best motor mount
    Quote Originally Posted by GTP131 View Post
    i made my own solid mounts. cause you cant really tell whats really solid or whats got oil filled.
    i drilled two holes in the mounts, drained, then blew the fluid out, let it dry, then filled the mounts with p and l construction adhesive. then let them cure for like a week. i smeared the p and l over the top cause i got a good oil leak from the pan that leaks on my mount and kills it.
    nice oil leak view lol
  5. #5 Re: best motor mount
    Nov 2014
    winston salem,nc
    i did think about it alot haha i was like wtf maybe there is something about the 3.8 idk lol
  6. #6 Re: best motor mount
    my engine was sitting sideways in the bay, it would flop all over back and fourth when shifted in and out of gear. new lower motor and trans mounts fixed it.
    my old motor mount. nothing left to it.
    the rest of it lol i cleaned this all out of the sub frame.
  7. #7 Re: best motor mount
  8. #8 Re: best motor mount
    Nov 2014
    winston salem,nc
    sweet thanks for that link this will be easier then i thought, think i may get some liquid filled mounts and fill them air craft sealer or liquid nail, or maybe some poly ones from zzp
  9. #9 Re: best motor mount
    Nov 2014
    winston salem,nc
    Mines not side ways but tilts forward very east. but i probly will replace it all. how bad is it to do the lower? Sorry to ask so much but this is my first w body and can't afford to mess up anything as its my dd. and plus i use to be into the jdm crap so my mind is filled with fixing honda junk lol
  10. #10 Re: best motor mount
    Knoxville, TN
    Very nice work, I like what you did with your mounts. I've seen other guides for filling mounts as well. I will go this route if necessary, it would just be nice to have a real solid rubber option from the manufacturer so I don't have to mess around with filling/waiting.
  11. #11 Re: best motor mount
    the ones in the install thread look to be zzp mounts, those should be solid.
    i got my last set there form a member for dirt cheap, like two for one deal. so i just drilled and filled em. they do make the car vibrate like a muther tho. so if your not into a bunch of vibrations when stopped in gear, pass on solid.
  12. #12 Re: best motor mount
    SWPA
    I always giggle a little when you guys say you made "solid" mounts.
    To me these are solid mounts
    Those are what I have in my Stealth and the engine doesn't move at all with those babies.
  13. #13 Re: best motor mount
    Nov 2014
    winston salem,nc
    damn haha id hate to be in that car if it got a missfire lol
  14. #14 Re: best motor mount
    SWPA
    Quote Originally Posted by krsdadsps View Post
    It's really not that bad. After the first few minutes you get used to the little bit of extra vibration.
  15. #15 Re: best motor mount
    im still waiting for someone to make those for our cars. custom maybe the only way.
    these are what im used to for solid mounts. good old Chevy rwd mounts.
    rubber
  16. #16 Re: best motor mount
    Nov 2014
    winston salem,nc
    maybe we should all save the pic, email and tell zzp we want these lol maybe with enough people they will make some,
  17. #17 Re: best motor mount
    i feel it through the whole car, the mirrors shake like i got the bass on the sub turned way up lol
  18. #18 Re: best motor mount
    Nov 2014
    winston salem,nc
    http://www.amazon.com/DEA-A2796-Fron...ds=motor+mount do you all think i could use this mount and make it solid? or where sound i get one from
  19. #19 Re: best motor mount
    thats the brand i got. they sell what they claim to be a solid mount too.
  20. #20 Re: best motor mount
    Nov 2014
    winston salem,nc
    Yeah i seen them I'm just gonna do like yall and fill them myself
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  3. motor mount help
    By asite57 in forum General Tech Discussion
    Last Post: 06-22-2012, 10:27 PM
  4. motor mount
    By mosley in forum Introductions/Noob Questions
    Last Post: 03-11-2011, 10:11 AM
  5. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
