Thread: Cranks But Won't Start.
Results 1 to 20 of 28
  1. #1 Re: Cranks But Won't Start.
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    Anyone? Would love to be able to put this away for the winter. Need it to start though.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  2. #2 Re: Cranks But Won't Start.
    Canada
    If you changed the cps and it started.....i'd start there...maybe a bad connection where it plugs in on the harness or maybe the wires are damaged..... where its routed around the crank?......did u check to see if the car had no spark again?
  1. cranks no start
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2014, 06:09 PM
  2. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  3. cranks but no start...stumped
    By t79z28 in forum Introductions/Noob Questions
    Last Post: 10-25-2013, 03:14 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
