Thread: Trac button stays lit on 2K GP GT 3.8L
Results 1 to 6 of 6
  1. #1 Trac button stays lit on 2K GP GT 3.8L
    SE Level Member Switzersland's Avatar
    Colorado
    The "wide Trac" TRAC selector button (ON DASH) stays lit and seems inoperable. Was this a "gimick" or is it worth it & an easy fix ?
  2. #2 Re: Trac button stays lit on 2K GP GT 3.8L
    May 2012
    Where winter never ends
    what light?! The traction control light? Pics of said light??
    2000 Regal - Winter Beater
  3. #3 Re: Trac button stays lit on 2K GP GT 3.8L
    that usually leads to a bad hub or wire to the hub.
    the abs lights on too?
  4. #4 Re: Trac button stays lit on 2K GP GT 3.8L
    May 2012
    what he said if your talking about the T/C light
  5. #5 Re: Trac button stays lit on 2K GP GT 3.8L
    Nov 2012
    Tennessee
    Just in case, if the light resets itself when you turn car off and then comes back on later and/or your tach quits working at same time, you might investigate the crank position sensor. My 2000 gt was doing that and crank sensor fixed it.
  6. #6 Re: Trac button stays lit on 2K GP GT 3.8L
    Colorado
    the abs light is not on, The TRAC button is inop. also the drivers side HI BEAM has burnt out for the second time in a week.
  1. 3 button DIC to 5 button swap questions
    By pontiacguy86 in forum General Tech Discussion
    Last Post: 10-15-2016, 01:49 PM
  2. 04+ 3 button to 5 button upgrade
    By Mad Monkey in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2016, 05:00 PM
  3. ABS / TCS stays off
    By xDetroitMetalx in forum General Tech Discussion
    Last Post: 12-01-2010, 09:11 PM
  4. Stays in first!
    By silvermistGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2008, 02:42 PM
