Thread: Very sluggish acceleration
Results 1 to 11 of 11
  1. #1 Very sluggish acceleration
    Mar 2012
    South Beloit, IL
    My car has been having some interesting issues lately where it just does not want to make power. The car won't go over 3.5k RPMs ever, and if I put too much throttle in, it won't shift into the next gear and will start to actually decelerate. If I slowly stay in the gas, I can get up to speed, it just takes an incredibly long time.
  2. #2 Re: Very sluggish acceleration
    sounds like a clogged cat.
    year make miles, last known tune up? the check engine light on? does it flash when you floor it?
  3. #3 Re: Very sluggish acceleration
    Mar 2012
    South Beloit, IL
    Thank you! That's what I thought, I tried to free the downpipe to resonator bolts but just can't get good torque on them under the car so I am taking it to the guy I bought the car from. He's offering to fix it for free but he seems to think it isn't the cat. As he said, "It sounds like the car has flow", which I disagree.
    2002 Grand Prix GT, Last tune up about 3 months ago. SES is on, but doesn't flash when I floor it.
    To complement why I think it's the cat, the exhaust flow out the tailpipes is so low I can cover both with my hands and feel almost nothing. There are no exhaust leaks. Also, the engine runs hotter than normal.
  4. #4 Re: Very sluggish acceleration
    have you had the car scanned yet for the code? the code always leads you to the problem.
  5. #5 Re: Very sluggish acceleration
    Mar 2012
    South Beloit, IL
    Yeah I'll go scan it real quick, it's just a PITA cause my friend has my ELM327 so I gotta do it in HP Tuners. iirc, one is the TCC circuit in the transmission, and the others were the EGR not functioning correctly, but I replaced it with the one from my other car.
  6. #6 Re: Very sluggish acceleration
    those wont make the car do this.
    does it sound like a vacuum with a full bag when floored? like it just cant suck any more air? even tho it should? if so thats a clogged cat for sure.
    you can also take the up stream o2 out, this will make a large exhaust leak, if it runs better the cat is clogged up, cause the leak is pre cat.
  7. #7 Re: Very sluggish acceleration
    Mar 2012
    South Beloit, IL
    Ok, just scanned, the codes were a matured misfire (had 4 and 6 reversed when I changed plugs) and EGR circuit. It definitely has that sound like a vacuum. I'll go try the O2 sensor.
    On a side note, when I got the car, the guy I bought it from had put ACDelco iridiums in there and I didn't know if they were old or not, so I switched them out with Autolite 106's. In this whole process, one of the things he told me to switch was the spark plugs back to the original ones. It seems like the car runs worse now, during acceleration it kinda stutters a bit. Also, if I rev the engine way up and let go, it stumbles and almost kills.
  8. #8 Re: Very sluggish acceleration
    SE Level Member GT in Kennesaw's Avatar
    Kennesaw, GA
    Quote Originally Posted by Nchristopherson View Post
    I've had those exact symptoms on my 01. Twice. Both times the dealer replaced the cat (warranty). Both times it fixed it. There are 2 causes for the cat clogging. 1) there is some ceramic parts where the exhaust enters the cat which break up and literally block the exhaust flow. 2) is worse. metal from the pistons, cylinders and rings wears off and eventually causes the same symptoms. I'm only familiar with #1, and do not have any verification of #2, just was told that by the dealer.
  9. #9 Re: Very sluggish acceleration
    SE Level Member jimzssei's Avatar
    Sep 2014
    Just throwing this out there... Fuel pressure? Fuel filter?
    Sent from Browns country
  10. #10 Re: Very sluggish acceleration
    Mar 2012
    South Beloit, IL
    That did it! Replaced the cat with the one from my other car and it's running like it should now thanks!
  11. #11 Re: Very sluggish acceleration
    good to hear.
  1. 02 gtp sluggish at low rpm's
    By Wkg318GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2012, 06:25 PM
  2. 98 Grand Prix GTP 3800 II, Troubleshooting Rough Idle and Sluggish Acceleration :(
    By 850Fishing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2012, 10:44 AM
  3. Sluggish
    By Mad Monkey in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-14-2010, 04:18 AM
  4. Sluggish crank
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2009, 02:21 PM
  5. sluggish
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2009, 11:44 PM
