Thread: Exhaust
Results 21 to 40 of 42
  1. #21 Re: Exhaust
    Aug 2013
    McDonald PA
    Quote Originally Posted by gordster1122 View Post
    damn $135 for a stock muffler my flowmasters were $80 brand new lol
    Get thrush turbos. Same sound actually deeper sounding than stock but quiet
  2. #22 Re: Exhaust
    May 2012
    Canada , Sarnia
    will they drone
  3. #23 Re: Exhaust
    May 2012
    Canada , Sarnia
    was looking on amazon.com and seen they had Walker Quiet-Flow Stainless Steel Muffler for $97.06 a muffler how are these ?
  4. #24 Re: Exhaust
    thats pretty much what i got, a walker stock muffler, its the one just cheaper then then the high dollar one thats aluminized.
    on my single exhaust, its quiet. how i like it really. i got a in car vid for quiet sounding exhaust if you like.
  5. #25 Re: Exhaust
    May 2012
    Canada , Sarnia
    ill check out the video and perfect want it quiet hate my super 44 just had to drive 2 hrs the other day the drone was pissing me off lol and these one don't drone at all ?
  6. #26 Re: Exhaust
    mods are in my sig. single exhaust. so maybe a bit tamer then a gtp's duals.
    http://vid1097.photobucket.com/album...ps2f3e4af2.mp4
  7. #27 Re: Exhaust
    the muffler. and the glass pack. its a 32 inch with one inlet cut off and a flange welded to it so it can be bolted in like it should.
  8. #28 Re: Exhaust
    May 2012
    Canada , Sarnia
    my 2 choices
    - Borla Pro XS
    - Stock Muffler Walker Brand
  9. #29 Re: Exhaust
    Enfield, CT
    my 2 choices
    - Borla Pro XS
    Walker parts will rust out on you quickly
  10. #30 Re: Exhaust
    my walker muffler is still good 3 years later.
  11. #31 Re: Exhaust
    May 2012
    Canada , Sarnia
    have to get my exhaust leak fixed tomorrow and get mufflers looking at the walkers right now on amazon.com everything is way overpriced over here in Canada
  12. #32 Re: Exhaust
    my walker was 95 at napa here. they had one better for 110.
  13. #33 Re: Exhaust
    May 2012
    Canada , Sarnia
    that's not bad
  14. #34 Re: Exhaust
    Antioch, IL
    **** walker, super turbos are as close to stock as you will get aftermarket, just get a mellow deep rumble, excellent stock replacement muffler, not loud at all
    2009 Challenger SRT8
    Expert at being gay.
  15. #35 Re: Exhaust
    May 2012
    Canada , Sarnia
    do you mean the dynomax super turbo mufflers?
  16. #36 Re: Exhaust
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    http://youtu.be/HZ41q51beyY
    My borla exhaust. I'm very happy with the way it sounds.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  17. #37 Re: Exhaust
    Antioch, IL
    dynomax, thrush, summit all the same
  18. #38 Re: Exhaust
    Enfield, CT
    Quote Originally Posted by ITHURTZ View Post
    Walker makes Dynomax guy. Sam had the dynomax kit which was good overall except the mufflers. the kit comes with super turbos. Problem is with super turbos is they rot quick. reviews show it and many customers I had complained as well. Her's rotted out real bad a little after 1.5 years but have a LIMITED lifetime warranty. Limited lifetime means you can only replace it once anytime in the future and then you get a 90-day warranty.
  19. #39 Re: Exhaust
    Antioch, IL
    oink oink
    funny my super turbos were spotless when I switched them out.
  20. #40 Re: Exhaust
    Enfield, CT
    oink oink
    Probably because your garaged your car...
  1. Magnaflow exhaust vs zzp exhaust.
    By 01GT guy in forum General Tech Discussion
    Last Post: 02-13-2014, 11:12 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
