what broke on your hose? or is it missing?
my cap took a dump and cracked, so i cut the tube off the cap put it between the two hoses, the one in the tank and the other to the rad cap, then sealed it with a shrink tube, stuck the tube int he tank under the coolant line, cut a v in the cap so the line fit into the tank. no leaks any more now.
you can see the edge of the shrink tube at the edge of the cap. so you can cut and splice it id its broken or pinched and leaking.
