Thread: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    I have a 2004 Grand Prix 3.8 N/A with 153,xxx miles.
    The car has been running like a great piece of crap with black soot on the rear bumper that has been coming out of the mufflers. Car is throwing P0202, P0204, P0300 codes. Most recently the check engine light has been blinking and I get 6 total codes with all three of those along with the "in progress" codes. I know the codes are injectors 2 and 4 along with random misfire. I ohm tested all 6 injectors and they all came back around 13.3-13.4 after the car running for a few mins, and then after sitting overnight they were all 12.1-12.2.
    While I was testing all of those I decided to pull the plugs and wires and replace them as they were factory. Replaced with brand new Delco wires and delco iridium plugs gapped at .060 (both factory). After replacing all of these the car ran the same. (which I didn't expect any differences)
    What should be my next step. I was thinking of trying to test voltage at injectors 2 and 4 to see if they are getting the required voltage from the PCM. And possibly just buying another PCM and replacing it as there are a few boneyards within a few miles that have them for $50.
    Am I missing anything? Any help would be appreciated.
  2. #2 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    http://www.obd-codes.com/p0202
    http://www.obd-codes.com/p0204
    two injectors aint working right, clogged or the wires are damaged or they are unplugged.
    po300 is multiple misfires, from the injectors not working right. more then likely. or it could use a tune up real bad.
    so basically, your running on 4 cylinders.
  3. #3 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    oh take a side bulb out of the head light, the small light, un plug one of the suspect injector plugs and push the bulb socket end in the pkug, go fire up the car, see if the bulb is flashing or now, if not its not getting power.
  4. #4 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    Yeah. I looked up the codes. I just swapped injectors from cyl 2 and 4 with cyls 1 and 3, cleared the codes and started it up. Codes came on again same ones. So I am to check voltages at injectors next. If voltages are low or erratic a bad PCM or short in the wires is likely correct.
  5. #5 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    see someone here have a injector problem and it was caused by rubbed through wires at the pcm harness. if you have a open cone air filter this is more possible to happen.
  6. #6 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    Hmm. Interesting that you say that. I pulled the PCM and the middle harness does have at least 2 wires that the silicon is rubbed off of a little but and some strands of the braid is exposed. Do you have a diagram of those wires to see which ones these wires are?
  7. #7 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    i dont, but if you see bare wires, fix that up.
  8. #8 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    should i cut out sections and solder in new pieces or push the braids back into the silicon best I can and tape it up?
  9. #9 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    i would solder only, with shrink tubes so its a weather tight permanent repair.
    it depends if the bad area will reach after you cut it, one splice is better then 2, so if you can cut the bad area and re splice it back together thats best, if it wont reach any more you'll have to add some wire and make two new splices.
    do make sure you strip the wires back till you see clean shinny copper wire, if its brown and tarnished the solder wont stick at all.
  10. #10 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    Thanks for the tips. I'll try that now. Hopefully that is my issue and I won't have to buy a PCM. I'll report back
  11. #11 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    oh. after you cut the wire, before you solder, dont forget to put the shrink tube on the one side of the wires. you need to slide it over the splice, then use a lighter to shrink the tube tight.
    search you tube, lots of good soldering vids. how to twist the wires to what solder to use. i use thing flux core solder from radio shack. runs like 5 bucks a tube. the tube i bought 4 years ago is just coming to its end.
    HF has cheap soldering irons if you need one, and shrink tubes. both run around 3 bucks each.
    having a soldering kit is one of them things we all should have on hand, its the one thing you never know when you'll need it till you need it.
  12. #12 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    I replaced the two wires that were frayed. One was green with black stripe, other was blue with black stripe. Both wires corresponded to injector 2 and 4 plugs. (Ohm tested to confirm). Who would have guessed. So I cut, spliced, soldered, & shrink wrapped them. Plugged back in the PCM, replaced the neg battery terminal, cleared the codes, started it up and now I only get a P0300. The P0202 and P0204 is gone.
    I still have the P0300 code though. Engine is stumbling like mad. There were two other wires in the same bundle that were melted a little bit but they were not broken or had any braid exposed so I didn't replace those sections. I'm thinking now that I probably should.
    Is there any other items that could cause the P0300 besides that?
  13. #13 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    you did say you changed the plugs and wires right? double check the plug wires are on right. it happens, hell i crossed 2 up my self not to long ago, fired it up ws like ok some thing on wrong, double checker 2 were wrong.
  14. #14 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    Yeah, I just double checked.. They are all where they should be.
  15. #15 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    maybe fix the other suspect wires, never know whats going on inside the insulation if it looks questionable.
  16. #16 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    k. will do. thanks and I'll post back to see whats happening.
  17. #17 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    I just replaced the 3 other suspect wires. No change. Still have a flashing CEL and P0300.
  18. #18 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    that usally mean one of two things, clogged cat or ignision related, coil, icm, tune up. crank sensor harness to icm.
  19. #19 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    Nov 2010
    Northeast, Ohio
    Well I tested the coils and the wires. All 6 had no issues and showed spark. I just did the plugs along with the wires. There isn't an external fuel filter (its in tank). I'm stumped.
  20. #20 Re: P0202, P0204, P0300 2004 Grand Prix N/A *Need Help*
    pull the o2 sensor out.
  1. Replies: 184
    Last Post: 03-30-2014, 07:51 PM
  2. 2005 Grand Prix 3.8L suddenly doesn't want to run then shoots a P0300
    By Grindal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2013, 12:39 AM
  3. P0202 code
    By Pipefitterone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2012, 07:48 AM
  4. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
