What Scotty means in the second part is: Your PCM resides inside the airbox (where the air filter is). In order to save yourself from getting raped for a PCM from the junkyard, you can simply find another 97 GT, remove BOTH the PCM and the airbox and before you walk up front to pay you have the PCM tucked back into the airbox where it started and they only charge you for the airbox assembly and you get a free PCM.
