Thread: Persistent Check engine light
Results 1 to 2 of 2
  1. #1 Persistent Check engine light
    Mar 2014
    Buffalo
    MY GP had a new jasper engine installed about 10,000 miles ago and ever since the check engine light has not come off. I've replaced every other part firewall forward and still it is on. Had a rebuilt transmission installed, two new axles, changed the cat 3 times, thinking it was that, just changed spark plugs and every single spark plug wire, and changed o2 sensor twice, changed maf sensor, changed engine thermometer, and now I wondering if there is anything I'm missing. My car is the 2006 base model with the N/A 3.8 the abs light is also on apparently there is a short in that system because it goes of anytime it rains or gets wet. Does anyone have any suggestions about what I should look at next?
  2. #2 Re: Persistent Check engine light
    whats the code? we cant help with out the code its throwing. sounds like your tossing parts at it aimlessly.
    check the wire to the plugs at the hubs for damage. unplug em clean and grease the plugs. you can also pay to have it scanned for abs codes at a shop.
    parts stores will read the engine code for free. some times the newer cars will show a abs code with the parts store scanner, rare tho.
  1. Check engine light comes on then goes off
    By BeezyPlatt in forum 5.3L V8 (LS4)
    Last Post: 12-20-2012, 01:27 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  5. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
