Yea pretty much. There were parts where there was tape under the wiring loom holding the wires together so I reapplied new tape to where the previous was at and then reused the same wiring loom and then taped that with new tape. You pretty much want to put it back the same way as when you took it apart. I also taped the sensor wiring where it will stick up instead of leaving it hanging down below to keep it from possibly touching that crossover pipe or touching something hot and melting the wires.
