Thread: Oil leak near lower area of belt
Results 1 to 19 of 19
  1. #1 Oil leak near lower area of belt
    Aug 2008
    Louisville
    I get 5 to 10 drops of oil when the car sits overnight. Never have to add oil between changes. Noticed a leak down by the lower pulleys at the bottom of the belt. Not sure where to start. Suggestions?
  2. #2 Re: Oil leak near lower area of belt
    looks like the crank seal. the balancer needs to come off to change it. id clean that all up with de greaser, then watch it closely to make sure its from the seal.
  3. #3 Re: Oil leak near lower area of belt
    Just follow this video, I know hes working on a 3.1 but its the same concept for the 3800 just different sized bolts. And I am not gonna lie that seal is a real stubborn ***** to get in. And remember the bolt on the balancer is reverse threaded.
  4. #4 Re: Oil leak near lower area of belt
    Quote Originally Posted by Slick2500 View Post
    Since when? Every crank bolt I've ever pulled off a 3800 was normal thread.
  5. #5 Re: Oil leak near lower area of belt
    Than what bolt am I thinking of?
  6. #6 Re: Oil leak near lower area of belt
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    As stated, clean the area good and then look for a drip falling onto that silver bolt. Mine only dripped with the car running. My problem was the harmonic balancer seal
  7. #7 Re: Oil leak near lower area of belt
    Dude replace your motor mount.
  8. #8 Re: Oil leak near lower area of belt
    Aug 2011
    Michigan
    Yeah, the rubber is a bit messed up on it. It's actually quite solid still though
  9. #9 Re: Oil leak near lower area of belt
    Feb 2013
    utah
    if it is the seal make sure you replace it with a factory on i repaced my wifes three times with three diffrent brands they would last anywhere from 2 weeks to 6 weeks factory one has held up for a 18 months
  10. #10 Re: Oil leak near lower area of belt
    I have a Fel PRO in my car been there since March of 2013
    Sent from A Galaxy Far Far Away........
  11. #11 Re: Oil leak near lower area of belt
    Aug 2011
    Michigan
    I think one of the tensioner pulleys is reverse thread
  12. #12 Re: Oil leak near lower area of belt
    Oh **** yeah the alt or supercharger tensioner is iirc.
  13. #13 Re: Oil leak near lower area of belt
    the one on the alt bracket is. some bonnie and park aves have the reverse bolt on the sc tentioner.
  14. #14 Re: Oil leak near lower area of belt
    SE Level Member tgarison's Avatar
    Abilene, Tx
    I to had a leak from the front main seal so I replaced with one from Timkin and now its leaking 10 times worse then before, I know I got it in there and flush with the block and I cleaned that area before installing it so what gives? I'm so confused I really don't want to take all that back off due to it being a major pita. Please help me.
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  15. #15 Re: Oil leak near lower area of belt
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by tgarison View Post
    Get a stock acdelco crank seal. Had thr same issue with 2 timkins, got a 10 dollar acdelco wlone from dealer stopped it right away.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  16. #16 Re: Oil leak near lower area of belt
    Abilene, Tx
    OK sorry, it took so long to get back to you guys on this, I replaced that piece of junk Timkin with a Genuine GM Part from the local dealer and its still leaking, not anywhere near as bad as it was with the timkin but its still dripping, I'm almost willing to bet it has a lot to do with the mileage the car has around 200,600 miles or so on the clock. Any ideas? Also it feels like the car has absolutly no balls at all when I get on it.
  17. #17 Re: Oil leak near lower area of belt
    Montgomery, IL
    You may need this since you have such high miles..the old gasket wears a grove in balance..put this sleeve on balancer and it should help..it took mine about a week of dripping after a gm gasket and the sleeve then it went away.
    Product List
    http://m.autozone.com/autozone-mobil...alancer+sleeve
  18. #18 Re: Oil leak near lower area of belt
    Montgomery, IL
    You also have a pcv or vacuum.problem if it has no get up..maybe building to much pressure in crank case and causing seal to blow out. Check.lines and pcv.
  19. #19 Re: Oil leak near lower area of belt
    Abilene, Tx
    I'll have to check those thanks
  1. belt area rattle
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-26-2011, 05:58 AM
  2. Loud rattling noise coming from belt area
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 10:06 PM
  3. Whining sound from Belt area
    By jonnyo81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 09:57 PM
  4. Rattling/Knocking Coming from Pulley/Belt Area
    By pc305577 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 09:32 PM
  5. weird noise from supercharger/belt area
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 07-06-2009, 02:40 AM
