Thread: is there a teardown/rebuild how-to written up for the 3800 series 2?
Results 1 to 5 of 5
  1. #1 is there a teardown/rebuild how-to written up for the 3800 series 2?
    May 2014
    Georgia
    So imma try to get this engine back working.I would just like to have something to look at. Thanks for reading.
  2. #2 Re: is there a teardown/rebuild how-to written up for the 3800 series 2?
    The short answer is you would want an FSM or other source for that. Without knowing how far you plan to go, keep in mind if this has an issue and you need to tear it totally apart, you want a machine shop to go through it for you.
  3. #3 Re: is there a teardown/rebuild how-to written up for the 3800 series 2?
    hangover park IL
    best i could offer are my build threads/oiling threads that SOMEONE still has not copied fer over here
    ~James~ Psychotic Gearhead
  4. #4 Re: is there a teardown/rebuild how-to written up for the 3800 series 2?
    Cambridge, Ontario Canada
    In the end, a used JY motor is your best & cheapest bet if this rebuild is anything but a race setup imo.
    2005 E55 - stock
  5. #5 Re: is there a teardown/rebuild how-to written up for the 3800 series 2?
    Yup a jy engine should cost you at the most $500, rebuilding a 3800 would cost you at the least $800 just for machine work, then figure in $200-$400 for bearings, gaskets, fluids and other misc stuff.
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. '05 GP GT 3800 Series III LIM/UIM
    By goochman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2012, 01:00 PM
  3. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  4. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
