Well.. oil shouldn't be there. So you need to fix that
Pcv is on the other side of the intake? I think I have my l26 uim vacuum line routed wrong.. I have it going from the uim to the adapter plate nipple
We've gone over this 100 times. You know it's wrong, but you are too busy to do it properly.
I dont know how to do it properly. I have the fuel rail and tranny on the actual tb nipple and the uim going to adapter plate
So does the uim one have to go to the intake tube? Before maf?
Please see my suggestion at the bottom again.
Originally Posted by BillBoost37Originally Posted by BillBoost37
Bahah.
Tim....
Read the following:
I told you. Use the pictures of where he drills the throttle body and puts a nipple. That is where the hose goes from the nipple on the UIM, because that nipple is vaccum for the pcv.
But he also says if you have an adapter plate with a nipple you dont need to drill the hole.
Doesn't matter what he said, because you didn't read all of it. Do as suggested and you will no longer have the oil issue.
Ignore the clear vacuum line it was swapped for a real one. Was temporary.
My attempt at getting the evap **** to work. But I dont get tested so I said screw it
Thats an old pic most wires have been tucked
