Thread: Acceleration Stuttering?
Results 1 to 20 of 32
  1. #1 Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    Recently my car has been kind of stuttering on acceleration. It also kind of jolts back while driving at a constant speed. Anyone have any idea? I already tried unplugging the MAF sensor, didn't work. Changed the fuel filter, air filter, oil and oil filter, plugs and wires. I'm all out of ideas except maybe a few other sensors but I don't know which ones it could be.
    EDIT: The catalytic convertor has recently been changed for being clogged so I don't think that's the problem
    EDIT: I'm driving a 2002 Grand Prix GT
  2. #2 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    Also I forgot to mention that I just had the catalytic convertor changed for being clogged so I don't think that's the problem.
  3. #3 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    what do you drive?
  4. #4 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    Sorry forgot to mention that as well 2002 Grand Prix GT
  5. #5 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    how many miles is on the car and have you serviced the trans?
  6. #6 Re: Acceleration Stuttering?
    Feb 2013
    37.295091, -121.930053
    when was the last service done on your tranny?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    When my cat was clogged I changed my filter and fluid that was about 9 months ago. There is about 170,000 miles on my car
  8. #8 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    any codes?
  9. #9 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    It's not giving any at the moment, would it be worth it to look at the TPS/O2 sensors or does this not sound like them?
  10. #10 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    not sure....
  11. #11 Re: Acceleration Stuttering?
    Mar 2012
    NC
    What do you mean by kicking and jerking? How are the shifts (hard/soft?) TPS would TYPICALLY throw a code, but not always. It can be checked using a voltmeter...should start out at .5v ish at closed throttle and gradually increase to about 4.5v wide open throttle. If the voltage drops randomly, you got a bad TPS.
  12. #12 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    I'll be driving and it will kind of jolt back for a second, as if the power being outputted by the engine dropped by like 75% but only for about half a second and then it kicks back up which kind of causes it to kind of jolt. I'll check the TPS with a volt meter and let you guys know, if I were to disconnect the TPS and it was malfunctioning would the car run more smoothly? Or would that not be a good way to tell if it's bad
  13. #13 Re: Acceleration Stuttering?
    Mar 2012
    NC
    That won't give you a definitive answer. Could be a crank position sensor dropping out too. Just thought about that. Might be losing spark for a sec until the computer picks it up.
  14. #14 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    I just checked the check engine codes and it says there's a bad speed sensor, could this be the problem?
  15. #15 Re: Acceleration Stuttering?
    Mar 2012
    NC
    If it's the engine speed sensor then it's talking about the crank position sensor as I previously mentioned.
  16. #16 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    what was the actual code number?
  17. #17 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    ninja'd.....
  18. #18 Re: Acceleration Stuttering?
    Mar 2012
    NC
    Quote Originally Posted by below average joe View Post
    ninja'd.....
    bwahahahahaha!!
  19. #19 Re: Acceleration Stuttering?
    Sep 2012
    Cedar Rapids, Iowa
    I think it said wheel speed sensor
  20. #20 Re: Acceleration Stuttering?
    Aug 2011
    'Merica
    then that would not cause you issue
  1. 04 Grand Prix Stuttering on acceleration
    By NewtoGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2014, 11:57 AM
  2. Acceleration Stuttering?
    By Pokealong1227 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2013, 02:16 PM
  3. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  4. 97 gtp stuttering
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2011, 02:02 PM
  5. Stuttering?
    By Southern Yankee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 09:20 PM
