Thread: Used 04 GP 150K acceleration problems
Results 1 to 13 of 13
  1. #1 Used 04 GP 150K acceleration problems
    Apr 2014
    Ontario
    tach bounces, shifts weird, hesitates as pedal is pressed, jerks twice every once in a while as I leave a green light and when 1/4 tank of gas when idling it makes a repetitive rumbling noise
    I just bought this car last month and I really like it besides the problems. I have replaced the gas cap and when i checked the old air filter was WAAAAY dirty so i bought a new one. I got a gas cap code, then a large evap code and the symptoms mentioned above. The dealer had plugs replaced but not wires. Im told some of these things can be the crank position sensor, the evap vent solenoid, the fuel canister, map sensor or clogged catalytic converter. My dealers mechanic is a bozo so I could use you guys help right now! THANKS GUYS!
  2. #2 Re: Used 04 GP 150K acceleration problems
    change the plug wires. check to see what plugs they put in too. should be iridium plugs used. not plats.
    the evap leak pull the driver side back tire and the plastic wheel well cover, in the front of the quarter panel is the evap canister, check its lines are tight and not cut or off. theres a solenoid on the tank too, check its wires.
    post the code you got if you have it still.
  3. #3 Re: Used 04 GP 150K acceleration problems
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Just my 2 cents, but it sounds like the care was not well cared for and it lacking in maintenance. In addition to what Scottydoggs said, give it a complete tune up.
    Filters: Air Filter, Fuel Filter, Cabin Filter, Oil Filter
    Check/Replace plugs and wires
    Clean Throttle Body
    Clean/Replace PCV valve
    Do a pan drop and replace the transmission filter and top off the fluid.
    Flush the cooling system well. I'm hoping this was done by 150K or it's going to be bad in there.
  4. #4 Re: Used 04 GP 150K acceleration problems
    GTP Level Member
    Aug 2012
    st louis park, MN
    No one mentioned to buy some Mass Air Flow (MAF) sensor cleaner and clean your MAF.
  5. #5 Re: Used 04 GP 150K acceleration problems
    Apr 2014
    Ontario
    The guy flushed and changed tranny fluid, brakes, plugs, thermostat and I think it was because his mechanic was trying to pin point a problem. I bought some intake cleaner so ill give that a shot too. Im just waiting for a good day to drop it off at the dealerships mechanic since it will be free
  6. #6 Re: Used 04 GP 150K acceleration problems
    GTP Level Member
    Aug 2012
    st louis park, MN
    Yea, flushing the transmission fluid was a bad idea unless you know the car's maintenance history. Also, why are you bringing your car back to the dealer if the mechanic is a bozo? Don't bring the car to someone you don't trust.
  7. #7 Re: Used 04 GP 150K acceleration problems
    St. Louis
    What plugs did they install? Should be irridiums, not platinums. Also, change the wires if they haven't been. Often just replacing plugs leads to a wire (or more) getting broken from being pulled off the plug. It may "look" ok, but leak voltage when reused. Simple test would be to start the car and pop the hood in a pitch black garage and spray a mist of water around all the plug wire boots at the coils and plug ends and look for tiny blue/white arching. If they are leaking it should be easy to spot.
  8. #8 Re: Used 04 GP 150K acceleration problems
    Pennsylvania, USA
    Flushing a transmission is always a bad idea, I'm irritated by how many transmission shops still suggest doing so.
  9. #9 Re: Used 04 GP 150K acceleration problems
    Eau Claire, WI
    A power flush ruined my transmission on my '94 Bonneville. Never again.
  10. #10 Re: Used 04 GP 150K acceleration problems
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    maybe check your vacuum lines too. couldn't hurt
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  11. #11 Re: Used 04 GP 150K acceleration problems
    Apr 2014
    Ontario
    Quote Originally Posted by stocker View Post
    He is replacing part by part for free. If I had the money I would say **** it and do it all myself.
  12. #12 Re: Used 04 GP 150K acceleration problems
    SE Level Member Gpmadness08's Avatar
    Sep 2013
    Peoria IL
    I'd check idle air control valve
  13. #13 Re: Used 04 GP 150K acceleration problems
    Eau Claire, WI
    Quote Originally Posted by Gpmadness08 View Post
    The '04 + is a drive by wire system and doesn't use an idle air control valve. That all changed with the last gen.
  1. 99 Grand Prix GTP acceleration problems!
    By trapper1306 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2013, 09:53 AM
  2. Acceleration problems.
    By 2004GrandPrixGT1 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-18-2012, 10:52 PM
  3. Acceleration pedal problems
    By Storm Smith in forum General Tech Discussion
    Last Post: 08-29-2012, 08:10 PM
  4. 97 L36 Acceleration Problems
    By gpaddictiongtp9798 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2010, 11:20 PM
  5. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
