Ok I give what is IIRC.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Would a 1.9 rocker swap require tuning?
3.4 pulley?
I'm learning :-)
your n/a. so the supercharged cars come with a 3.8 sc pulley, some can drop to a 3.4 pulley with headers 1.9 rockers and no tune, every car is a bit different what works for this guy may not work for the other guy.
so yeah, you could run rockers with out a tune is what i was getting at.
What is a 3.4 pulley
Dude it's a sc pulley. Not the thing you need to worry about if your n/a please read the safely modding thread.
I have it has very little to do with a N/A car
and thats because its not really worth modding them, most see like 200 hp out of a n/a on a dyno. (modded) it come stock at like 180 ish to the wheels.
top swap would put you around 240 give or take, add a cam it goes up, drop a pulley it goes up some more. top swap is heads lower intake and supercharger, balancer and the sc pulleys and idlers and tensioner from a l32 or l67 put on a n/a block. cost like 400 or less for all of that, then you need new head bolts, headers and gaskets for it all. around a grand all in all.
turbo would be any where from 250 to 500 depending on the size of the turbo and such.
