Thread: I am thinking of camming.....
Results 1 to 20 of 31
  1. #1 I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    I am thinking of camming my 2007 pontiac Grand Prix N/A with the L26. The problem with that I am hearing is it will need a tune. Which I am fine with. My question is that since it's an 07 would I have to change to a 04-06 PCM? If I do change the PCM what is different? Will it change my driver information like my odometer? Will I need a different wiring harness?
  2. #2 Re: I am thinking of camming.....
    you would have to use a 04 pcm, iirc the gas gauge reads backwards tho. not sure if they worked something out for that yet or not.
    n/a engines even cammed are still kinda slow, why not cam and top swap and go all the way.
  3. #3 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    Don't need that much more power just a little. My other car I just bought will get a charger though.
  4. #4 Re: I am thinking of camming.....
    you may want to install headers with that cam.
  5. #5 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    I saw ZZP had a cam a while back that did not require a tune wasn't sure if it would be a good idea though. Headers are going on it anyway.
  6. #6 Re: I am thinking of camming.....
    Ehh not worth it on a n/a I would rather spend money topswapping it or turboing it.
    04 Comp G.
  7. #7 Re: I am thinking of camming.....
    id contact will at overkill. he seems to be good with the tuned pcm's of the 05 and up cars.
    you maybe able to run it with a stock tune, but lets face it, you'll get more out of it with a tune.
  8. #8 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    L26 does not do well with a top swap. Turbo is a possibility
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  9. #9 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    Either way I still need the tune which people keeps saying is impossible unless I switch to a 04-06
  10. #10 Re: I am thinking of camming.....
    I think if you use a 05 PCM it's possible but you probably should contact the tuner of your choice and confirm.
    04 Comp G.
  11. #11 Re: I am thinking of camming.....
    Quote Originally Posted by Spike89 View Post
    since when? turbo is way more of a power adder then a top swap could ever hope to be.
  12. #12 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    My questions are still unanswered though :-(
  13. #13 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    I read an article stating that the L26 has weak connecting rods.
  14. #14 Re: I am thinking of camming.....
    Well generally unless your going with a huge cam then no it's doesn't necessarily need a tune but if your going through all that work why wouldn't u tune it if a tune is not possible I wouldn't bother and would just stick to the intake hv3 maybe even rocker combo.
    04 Comp G.
  15. #15 Re: I am thinking of camming.....
    Plenty of guys have topped swapped l26 without any issues.
    04 Comp G.
  16. #16 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    What gains do you get with a rocker swap?
  17. #17 Re: I am thinking of camming.....
    contact will at overkill. he tune the newer cars, he can help you out the best.
    hes a vendor here, and has tuned many members cars. hes got his own section here, with the rest of the vendors, maybe you can find your answers in one of these threads.
    Will is also quite active here, so if you post he will reply sooner or later.
    http://www.grandprixforums.net/forum...ll-Motorsports
  18. #18 Re: I am thinking of camming.....
    Check out the safety modding thread.
    04 Comp G.
  19. #19 Re: I am thinking of camming.....
    Nov 2012
    Lebanon, Ohio
    What do you think of these.....
    http://shop.zzperformance.com/store/...r-Headers.aspx
  20. #20 Re: I am thinking of camming.....
    its been said around here that those crack and dont seal well iirc.
  1. 5.3 V8 LS4 Camming?
    By HPQueen in forum General Tech Discussion
    Last Post: 12-08-2013, 05:30 AM
  2. Camming this summer...gotta question...
    By rell2005 in forum General Grand Prix Discussion
    Last Post: 03-27-2013, 05:04 PM
  3. Thinking about get this set
    By jacobmh27 in forum Brakes/Suspension/Chassis
    Last Post: 09-02-2012, 07:49 PM
  4. Been thinking about a new car...
    By nicksilvergt99 in forum Off Topic Discussion
    Last Post: 12-24-2009, 06:18 AM
  5. Thinking about getting these...
    By Quicklynx in forum Off Topic Discussion
    Last Post: 10-21-2008, 10:30 AM
